Best Size Plowing Tire
12 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 17, 2012 - 09:23 PM
What would be the best size tire for plowing, moldboard plowing, with a garden tractor?
Which is better a narrow tire or wider tire or is there a certain size that works best?
AG lug tires, no liquid ballast added.
6 - 12
23 x 8.50 - 12
23 x 10.50 - 12
26 x 12.00 - 12
Edited by DH1, April 17, 2012 - 09:24 PM.
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 17, 2012 - 09:27 PM
For snow I was always told the narrower the better, but for drit and mud wider the better.
Snow - you want to sink down to somthing solid (cut down thru the snow)
Dirt - You want contact surface with the ground
My pic is either 23x8.50-12 or 23x10.50-12
  • DH1 said thank you
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 17, 2012 - 09:28 PM
The 8.50's I had on the Caterpillar last year plowing with only 60 pounds of wheel weights per wheel and it did ok.
I drove it in mud and snow (didn't really work it) and it has had both 10.50's and 8.50's on it, and yes both ags.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 18, 2012 - 04:49 AM
Doug, there is another discussion going on here with some interesting info. on tire size considerations for plowing. Heres the link http://gardentractor...-x-12-12-tires/ It sounds like there can be some problems with oversize tires that aren't that obvious.
#5 olcowhand ONLINE
  • 42,895 Thanks
  • 31,937 posts
Posted April 18, 2012 - 10:35 AM
Really, NOT too wide is better. 8.50's do awfully well. I go wide just because they look good. Actually, it's best not to surpass your plow width by much, so I'd say 10.50's would be prime for a 10" plow.
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted April 18, 2012 - 11:28 AM
I've noticed that with the wider tires (23 X 10.5 X 12) on my Wheel Horse 314-8, I have all the traction I will ever need. I'm pulling a 10" plow and it does a great job.
#7 ckjakline ONLINE
ckjakline
  • 1,144 Thanks
  • 1,135 posts
Posted April 18, 2012 - 12:14 PM
I use the 23x10.5-12 ags on my wheel horse raider 12 w/a 10in plow and a set of weights and it does fine.
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted April 18, 2012 - 08:50 PM
Ryan has the Deestone 10.50 tires.. They tend to run a little smallish, so call them 10" He rarely, if ever spins with weights. Total between weights and fluid is around 125 per side.
I have 8.50 turfs & chains on my Sears SS12. It did really well at Plowday. Rarely spun unless I was way over in a deep furrow. I only have 65# per side on it, so a little more wouldn't hurt any.
KK also has 8.50 & chains. She only has 50# per side. Her chains are 2 link spacing instead of 4 like mine. She was pulling the 8" plow and almost never spun.
#9 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted April 18, 2012 - 08:58 PM
One thing to remember is that a lot (most) of the gt tires aren't actually their marked size. The 26x12x12 carlise super lugs on my mf12g are really only 10 3/4 inches wide and fit in a 10" brinly's furrow fine. I do a good bit of plowing for peoples gardens and there are times I would have a really hard time without my 26x12x12's. If your plowing at a plow day or a pre-existing garden it's one thing but when your plowing virgin ground that was overgrown with weeds a few days before plowing you need all the traction you can get. My mf12g isn't the heaviest of GT's so I have a lot of added weight also. I have the tires loaded, 85 lb wheel weights on the inside and 55 lb weights on the outside. Believe it or not even with all the weight I still always bring a set of tire chains a long and there have been times I've had to chain up to get the job done. I have another mf12g with deestone 23x10.5x12's and it does okay at plow days with some occasional a$$ shifting.
Edited by broken2, April 18, 2012 - 09:00 PM.
#10 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted April 19, 2012 - 05:50 AM
I put the 26 X12-12 Carlise ags on 11.5" rims on the JD 140 and took them back off because I could not use the mower deck with them on. I am going to find a set of 23 X 10.50-12 t1res instead and mount them on 9.5 or 10" rims.
Bill
#11 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 19, 2012 - 08:23 PM
Thanks for all the info, looks like 23 x 10.50 - 12 is a good choice.
I know when you load the tires the bigger ones will be heaver for sure but for the same weight is the wider tire better than a narrow one???
I know form yrs ago for snow plowing tall skinny tires work better that the wide fat ones on a 3/4 or 1 ton snow plow truck, as was said before.
If you go off road 4wheeling in the mud the opposite is true, wide fat ones are better.
I always wanted to try a comparison, I have a set of AG 6-12s and a set of AG 23x10.50-12s maybe some day I should try both sets on the same tractor, keeping the tire/wheel weight the same and see what happens.
  • MH81 and wvbuzzmaster have said thanks
#12 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 08:27 PM
Sounds like you have a plan Doug. Glad we were all of some help in your decision.
#13 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted April 19, 2012 - 09:58 PM
I think it also depends alot on the size of garden tractor. I can tell I loose alot of torque on the 140 when I have the 26X12's on compared to the 23X10.50's. Would really like to have a pair of those new Firestone 10.50's to try out. :thumbs:
Mark
