Brinly Disc Harrow And ? Moldboard Plow
17 replies to this topic
#1 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted April 15, 2012 - 07:19 PM
I picked these up off the local Craigslist last week but had to drive 65 miles each way to pick them up. The disc harrow is a single by Brinly but I am not sure who made the moldboard plow since the depth adjustment doesn't look like the other Brinlys I have seen. I thought that maybe it was a repair but it looks factory.
I would like to find another disc harrow like this one to make it a double.
Opinions needed,
Thanks,
Bill
Edited by GTTinkerer, April 15, 2012 - 07:21 PM.
  • middleageddeere said thank you
#2 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted April 15, 2012 - 07:22 PM
I believe the plow IS in fact a Brinly, and that someone broke the original adjuster and used angle iron, all thread, and a welder to make it work that day.
Edited by wvbuzzmaster, April 15, 2012 - 07:23 PM.
  • GTTinkerer said thank you
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,729 Thanks
  • 2,603 posts
Posted April 15, 2012 - 07:30 PM
I don't know Casey, the coulter attachment doesn't look like the brinly plows either. The main frame also looks a lot heavier then a standard brinly too.
#4 ckjakline OFFLINE
ckjakline
  • 1,133 Thanks
  • 1,127 posts
Posted April 15, 2012 - 07:38 PM
Not sure what you have there. Ohio steel also makes plows does anyone know what they look like.They also have the brinly type hitch.I havn't seen any of them or how they look .The Brinlys i have use a cable clamp to hold coulter.
#5 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted April 15, 2012 - 07:39 PM
I think it has been cobbled on Troy. If they are cobbling one thing they might as well cobble another...
#6 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted April 15, 2012 - 07:48 PM
Here's a 10" Black Brinly plow.
edit added 2nd pic of it
Edited by DH1, April 15, 2012 - 07:59 PM.
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,729 Thanks
  • 2,603 posts
Posted April 15, 2012 - 07:56 PM
If you compare Bill's plow to Doug's plow, I don't see holes in Bill's for the coulter clamp. Maybe I'm wrong.
#8 Littledeere OFFLINE
Littledeere
  • 1,648 Thanks
  • 1,480 posts
Posted April 15, 2012 - 08:20 PM
Thats a Ohio Steel plow they weld there mount for the coulter
  • MH81, GTTinkerer and johndeereelfman have said thanks
#9 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted April 15, 2012 - 08:25 PM
That's why I think the plow is factory built because the two holes for the coulter clamp and the one for the front adjuster swivel/mount are not there nor does it look like they were welded over and ground down.
Thanks,
Bill
#10 johndeereelfman OFFLINE
johndeereelfman
  • 5,729 Thanks
  • 2,603 posts
Posted April 15, 2012 - 08:30 PM
Doug,
If you look under Brinly on ebay right now, there is a guy parting out a brinly plow, and may have the share to repair your's. I think his starting bid for each piece is $10.00. Just thought you might like to know, if you don't already.
Edited by johndeereelfman, April 15, 2012 - 08:33 PM.
  • DH1 said thank you
#11 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted April 15, 2012 - 08:31 PM
Thanks Littledeere. I did a search for "Ohio Steel plow and found this web site http://www.stevencha...76/5_Plow.shtml This photo was there.
The coulter on mine is froze to the shaft but a little help from the heat wrench should help that. And then a drill bit, tap and grease fitting will solve it in the future.
Thanks,
Bill
Edited by GTTinkerer, April 15, 2012 - 08:50 PM.
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted April 15, 2012 - 08:32 PM
There ya go, now you know what you got.
#13 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted April 15, 2012 - 08:39 PM
Ask and ye shall receive. Thanks for all the replies.
I went to Ohio Steel's web site for lawn and garden http://www.ohiosteel.com/lawntest.html and the moldboard plow is not there.
Bill
Edited by GTTinkerer, May 29, 2012 - 06:24 AM.
#14 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted April 15, 2012 - 08:51 PM
Doug,
Those are before and after pictures, it was broken when I got it.
#15 Littledeere OFFLINE
Littledeere
  • 1,648 Thanks
  • 1,480 posts
Posted April 15, 2012 - 09:07 PM
I went to Ohio Steel's web site for lawn and garden http://www.ohiosteel.com/lawntest.html and the moldboard plow is not there. Maybe my $50 plow is a "rare" item.
Bill
I don't think they have offered a plow for a long time There are at least 2 syles because I have 2 different ones one is like yours
I would say back in the early 80 's at least
