Step For My '71 1614
10 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted April 15, 2012 - 03:57 PM
Today I started making a step for my "71 so its a little easier to get onto. The top is 5x7 inches and the edge going around the outside is 1 inch. I cut notches out so it will look better and be a little stronger when I weld the pieces on to bolt to the frame. To bend the sides I scored the underside with my grinder so it would bend easy with good corners and make a nice seamless edge.
The two parts coming up will be bolted to the frame through the two slots. I will have to fill the smaller holes in with some weld and grind them flat.
I dont think it really 100% needs it but, I decided to weld a piece on the underside for a little extra support to keep it from flexing.
This is where I will mount it to the frame. I'm going to have to drill a hole in the frame for the front piece, the back will use an existing hole.
I got everything gridded and the edges filed, now I am waiting for welding gas so I can weld it together. I am getting my argon and oxygen bottles filled tomorrow so it should be welded together by tomorrow evening. Thanks for reading!
Edited by Ryan313, April 15, 2012 - 03:59 PM.
#2 KennyP ONLINE
  • 37,566 Thanks
  • 45,540 posts
Posted April 15, 2012 - 07:05 PM
Looking good, Ryan! Ought to make getting on/off easier!
  • Ryan313 said thank you
#3 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted April 16, 2012 - 05:17 AM
Nice work and a great idea, it is a long way up on my 2414 too.
#4 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted April 16, 2012 - 05:36 AM
Nice job on the step , the po put one on my 2418 and I'm glad he did ,makes getting on and off a lot easier , Al
#5 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted April 16, 2012 - 10:35 AM
Thanks guys! You can get away without one on a 16 inch model but even though a 24 is only 3 inches higher I think its needed.
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 16, 2012 - 02:30 PM
Great looking step Ryan, great fab work.
#7 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted April 17, 2012 - 04:04 PM
I welded it together, gridded and filed it yesterday and had enough time to paint it before dark.
Don't mind my ugly welds.
I put it on today.
It's so much easier to get onto now and getting off is much easier as well. I stood on it and bounced a little and it had no flex whatsoever. Now I need to make for the '75!
#8 KennyP ONLINE
  • 37,566 Thanks
  • 45,540 posts
Posted April 17, 2012 - 06:24 PM
Looks good to me, Ryan! Ugly welds still work! Glad it helps out!
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 17, 2012 - 08:32 PM
Great looking step Ryan, keep up the excellent work.
#10 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted April 17, 2012 - 08:37 PM
Thanks guys! Hopefully I can have one made for my '75 by this weekend.
#11 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted April 17, 2012 - 08:42 PM
Wow you built that like a tank !!! I wouldn't worry about those welds , I'd worry if I caught it on something I'd bend the FRAME , Al
