New To Me Amf 1010
9 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 14, 2012 - 05:40 PM
Here are some pics of the AMF 1010 I traded for a Cub Cadet 122. Don't know much about them; are they rare? It has a temcuseh hh100 in it. Runs good but it needs the carburator cleaned.The pretty concrete weights came at no extra charge. :rolling:
  • tinner said thank you
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 14, 2012 - 06:33 PM
Congratulations on the tractor. I'm not sure how rare thay are but they are certainly less common than the MF10 which is very much the same tractor. That one looks like a really nice example. Those wheel weights are priceless!
  • LTD said thank you
#3 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted April 14, 2012 - 06:52 PM
That is a good find.I don't think they are real common.You can share some parts off of mf 10.Later Josh
#4 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted April 14, 2012 - 10:58 PM
Well LTD, you've gone and done it.............now everybody will be asking you for specs. on the weights so they can build a like pair. :laughingteeth:
Nice looking tractor you've got there, it looks to be in real good shape. Congrats.
#5 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted April 15, 2012 - 09:12 AM
That AMF sure looks to be in great shape. it looks like it was well cared for. Nice weights too. Maybe have them chromed though.
#6 KennyP ONLINE
  • 40,855 Thanks
  • 47,081 posts
Posted April 15, 2012 - 10:22 AM
Nice tractor. Guess that's one way to add weight, but I would be concerned about the lime in the concrete and those wheels. Over time, concrete additives will eat thru rebar.
#7 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 15, 2012 - 01:00 PM
Calcium chloride will eat through rims a lot faster than the additives in concrete, and that takes 12 years.
I wouldn't worry about it.
#8 gbrown OFFLINE
gbrown
  • 20 Thanks
  • 90 posts
Posted April 15, 2012 - 01:41 PM
I like the tractor and the wheel weights. Now, the PO could've done it a bit differently and had something more aesthetically pleasing, but they are definitely functional and it is a tractor, after all. Good find.
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 15, 2012 - 04:10 PM
Thanks for all the nice comments guys. I cleaned the carburator and adjusted it today,still won't run quite right at idle though; then I did some mowing with it. It worked very well. I don't know if the concrete weight's have done anything to the rims or not as I haven't had them off yet.
#10 Oldtractorguy45 OFFLINE
Oldtractorguy45
  • 1 posts
Posted May 03, 2014 - 04:25 AM
A beauty! And very rare from what I have discovered. Recently bought my own, finishing rebuild pics coming. Because MF bought AMF they are basically the same. However, MF can't say their sister division made motor cycles - Harley Davidson.
I'm in the process of making mine a temporary working unit. Having issue with belt jumping off when I try to mow in third gear. I mow 3.5 acres. Just finishing up a deck update with new bearings, pulleys, blades etc. can't find blades though. They are 14" with rectangular opening. I'm planning to buy 5/8 hole style and machine out to fit. Anyone have better idea?
Also on the hunt for a front blade and snowblower, should anyone have such attachments.
