Bushhog D4-7 Transaxle S900
24 replies to this topic
#16 HowardsMF155 OFFLINE
  • 2,774 Thanks
  • 2,949 posts
Posted April 15, 2012 - 07:38 AM
You can use a knife sharpening stone (small is best)..........I guess you could say I'm a stoner. :laughingteeth:
How well would one of those diamond coated sharpening stones work? Great tips, by the way.
#17 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted October 09, 2013 - 05:31 PM
Well I am back to wanting to get this one up a running. I am in need of the rear axle mounts to attach the axle to the frame. It is different than the T-63 or the D4-10 models. I may end up having to use a D4-10 set up since the rest is the same....but would like to stay true to the original set up. Below is a diagram of what I am looking for. Willing to pay or trade for these parts.
#18 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted October 09, 2013 - 07:49 PM
Scott, does the early D4-10 use the same mounts?
#19 NUTNDUN OFFLINE
  • 10,304 Thanks
Posted October 09, 2013 - 07:52 PM
Sorry I can't help you out Scott. I have never had one of the transmissions apart other than taking the lid off my D4-10 just to make sure the gears looked good before I plowed with it. Definitely interesting to see how it looks all torn apart and I am subscribing to see the progress you make with it.
  • sacsr said thank you
#20 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted October 09, 2013 - 09:21 PM
Brian not sure, I am picking up an earlier model d4-10, so I guess I will see then, but I don't think they are the same. The axle tubing is much thinner and the transaxle casing is aluminum on the D4-7. So far I have never seen an aluminum housing D4-10, but I have not had an early model to compare it to.
Edited by sacsr, October 10, 2013 - 07:26 PM.
#21 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted October 10, 2013 - 10:25 PM
Scott, I early D4-10 is the same axle and mounts as the later ones.
     #9397
     #8495
#22 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted October 10, 2013 - 10:38 PM
I was figuring that was the case. So the set up I am looking for must have only been offered in these early D4-7's. I may have to convert a D4-10 mount if I can't find the correct ones. Thanks Brian for the pictures.
#23 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted October 10, 2013 - 10:42 PM
Not a problem Scoot, I am trying to see what all the differences between the early and late 10s.
#24 olcowhand OFFLINE
  • 38,812 Thanks
  • 30,704 posts
Posted October 14, 2013 - 06:31 PM
All my D4's have the same mounts as Brian posted pics of.  Are the axle tubes the same diameter as the JB tubes?  If so, I may still have the half round muffler type brackets off Hogzilla.  I had to cut them off my frame to mount the newer hydro.
#25 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted October 14, 2013 - 08:09 PM
Not sure I will check. Thanks
