Carburetor
5 replies to this topic
#1 JohnDeerematt OFFLINE
JohnDeerematt
  • 2 posts
Posted April 13, 2012 - 03:23 PM
I have a hand me down John Deere 212 with the Kohler k301 that needs a over haul I also have a k321 just sitting around with out a carb so I was wondering will the carb on the 12HP work on the 14hp
#2 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 13, 2012 - 05:35 PM
welcome to the forums
it should work okay
bacisly they about the same
a lot parts are interchangable
#3 KennyP ONLINE
  • 40,837 Thanks
  • 47,074 posts
Posted April 13, 2012 - 05:50 PM
:welcometogttalk: Depending what the K321 came out of, you may have a very easy swap there. I know someone more knowledgeable will be along to help on this. Stay tuned, sometimes takes a bit!
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 13, 2012 - 07:36 PM
Matt,
Yes, the carb's can be interchangable. The only thing is, the 12hp carb will have a smaller opening than the 14hp opening. Other than that, all adjustments and set ups will be the same. Good luck, and Welcome to the site.
Troy
#5 JohnDeerematt OFFLINE
JohnDeerematt
  • 2 posts
Posted April 15, 2012 - 11:32 AM
Will the diameter differance cause a problem on the 14HP
#6 olcowhand OFFLINE
  • 42,885 Thanks
  • 31,934 posts
Posted April 15, 2012 - 12:11 PM
It'll be fine on thew 14hp, but the smaller venturi would not work well on a 16hp K341.
