Kohler K161 Help
6 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 12, 2012 - 08:27 PM
Im tring to get this k161 running good and so far its been a tough battle. I got the points adjusted at .020" and clean. After less then 5 minutes of running it quit on me. During those five minutes it had a constant miss and the exhaust gets red hot fast. Tweeking the carb adjustments made no help. Prior to this i adjusted the points because the gap was too tight but it ran without overheating. Do i have a ignition timing issue now?
#2 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 12, 2012 - 08:33 PM
Sounds like the timing is too retarded or it is running lean. I think there is a manual in the manuals section for checking the timing on the Kohlers. I am not sure on it enough to explain it and don't want to steer you wrong.
#3 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 12, 2012 - 08:34 PM
Kenny posted a timing manual for the K series Kohlers: http://gardentractor...-static-timing/
#4 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 12, 2012 - 08:35 PM
Also here is the service manual which should cover it also: http://gardentractor...service-manual/
#5 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 13, 2012 - 07:36 AM
Im going to do the static timing and hope it runs better. If it helps i think i'll do this to all my kohlers.
thanks
Edited by bread320i, April 13, 2012 - 07:37 AM.
#6 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted April 13, 2012 - 05:34 PM
wow i like that way of timing . i got a kohler begging to be static timed
#7 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 14, 2012 - 07:37 AM
I looked at the K161 last night. The static timing instructions tells you theres an S for spark andd T for tdc on the flywheel. I see an SP and DC. I assumed the sp wss for spark, i havent tried to run it yet but im anxious.
