* * * * * 2 votes
Bolens Belt Sizes
80 replies to this topic
#61 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted November 12, 2015 - 09:40 AM
Well I tried that belt and it was to long. The belt that was on there is an 4L300 or A28
#62 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 12, 2015 - 09:59 AM
Thats strange was it one of mine or one that claimed to replace the 1714690?
Is your pulley the original OD and width? Thats the only thing I can think of as being the problem.
#63 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted November 12, 2015 - 10:02 AM
It was an original 1714690
#64 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 12, 2015 - 10:14 AM
Its got to be your pulley then......
#65 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted November 12, 2015 - 10:23 AM
There was another belt number - 1108464 - that was listed for the early hydraulic lift kits.
It was described as 31", which is also what the 1714690 belt is described as being.
Did the 1714690 supersede the 1108464 ??
Were either of these belts "half" sizes?
Were both of these belts 1/2" top width?
  • Bolens 1000 said thank you
#66 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 12, 2015 - 10:49 AM
Now that you mention that I think i remember coming across a partslist with that number in it, looking at Bolens spec sheets the 1714690 was cogged and a special 31.97''
1108464 was a regular wrapped belt shown to be 31''
  • Bruce Dorsi said thank you
#67 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted November 12, 2015 - 03:21 PM
This is the belt that I found works for the hydraulic pump on the 1000.
#68 Browning OFFLINE
Browning
  • 5 Thanks
  • 6 posts
Posted February 11, 2016 - 08:30 AM
I have just got our Ride-a-Matic (1960) running again after nearly 25 years - rebuilt the back end.
I am trying to select the correct v belts; have ascertained they should be B series according to the pulley groove widths.
The manual just says 24" and 42" - these cant be inside lengths because I have tried them and are way to big. It must be either the outside length or the pitch length (in between). Can anyone help? Otherwise I will attempt to measure or do trial and error.
#69 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted February 11, 2016 - 08:54 AM
Each manufacture has their own way of measuring the size
I have the correct ones here if needed, just send me a PM
#70 Bruce Dorsi ONLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted February 11, 2016 - 10:06 AM
The specified dimension is the outside circumference (length) of the belts you need.
Most, but not all, belts found in the lawn & garden industry are specified by their outside length.
  • Browning said thank you
#71 Browning OFFLINE
Browning
  • 5 Thanks
  • 6 posts
Posted February 11, 2016 - 11:59 AM
Thanks, I think postage would kill it to get them from your side.
#72 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted February 11, 2016 - 12:02 PM
Your probably right , didnt see you were from across the pond, postage about $23.00
#73 Browning OFFLINE
Browning
  • 5 Thanks
  • 6 posts
Posted February 11, 2016 - 12:15 PM
I think what you say ties up with my measurements - rather tricky. I believe most belts over here are specified by their inside length, but possibly different in the States.
#74 Bruce Dorsi ONLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted February 11, 2016 - 01:40 PM
Quite possibly different here.  .....I wasn't considering other countries in my post.
Most of our belts are sold under their inch size.  ...Do your equipment belts sold by inch or mm designations?
#75 ClassicBolens OFFLINE
ClassicBolens
  • 1,375 Thanks
  • 495 posts
Posted February 11, 2016 - 02:38 PM
B21 for the 24" belt (or 5L240), B39 for the 42" belt (5L420). Pretty much universal globally.
24" and 42" is the approximate outside length, 21" and 39" inside length.
