* * * * * 2 votes
Bolens Belt Sizes
80 replies to this topic
#31 themayor70 OFFLINE
themayor70
  • 4 Thanks
  • 12 posts
Posted April 28, 2012 - 02:52 PM
Meant to get back sooner on the pto belts. My 42" belts work fine as long as I have the lower belt guard on. I was missing my lower guard and the pto did run all the time but when I took the guard off of my 1256 and put it on my 1050 they worked fine with plenty of adjustment. Without the guard the belts are running in too much of an "oval" shape but the guard does a nice job of straightening it out so the pto shaft doesn't run anymore when it's idling.
#32 mark843 OFFLINE
mark843
  • 15 Thanks
  • 200 posts
Posted May 09, 2012 - 11:30 AM
I ordered the started belt as I have a v belt and it squeals and slips a little.
Thanks for the links and info.
#33 framesteer ONLINE
framesteer
  • 439 Thanks
  • 209 posts
Posted September 19, 2012 - 12:11 PM
I've had good luck with belts from JayDee Enterprises.
http://www.jdv-belts.com/products.htm
Here is a listing for belts by OEM part number, including Bolens.
http://www.jdv-belts...LOG 2.19.09.pdf
  • Bruce Dorsi and KennyP have said thanks
#34 dgard OFFLINE
dgard
  • 2 posts
Posted December 11, 2012 - 12:42 PM
Hello to all, am the owner of a Bolens ride a matic with the Kohler 7hp engine (guessing a `59 or 60 but happy to be set right). It has served well for years but when last serviced the belts were changed for ones that are totally wrong. I don`t have the old ones to work from so would really appreciate if anyone can tell me what drive belts I need to get hold of. We have the trailer, grass cutter and a roller for it and apart from massive belt slip it runs well. thanks daveG
#35 Bolens 1000 ONLINE
  • 15,461 Thanks
  • 18,291 posts
Posted December 11, 2012 - 01:26 PM
Do you happen to know the exact model number?
They used different size belts depending on model and year. Some pictures would also assist in identifying the year and model.
#36 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,989 Thanks
  • 2,480 posts
Posted December 12, 2012 - 09:30 AM
If you go to the Bolens Ride-A-Matic section of the Manuals forum, you may be able to identify your tractor by comparing the manuals for the various model tractors. Link: http://gardentractor...5-ride-a-matic/
If your tractor is like the one in your avatar, it is a 1959 (model 230), a 1960 (models 231 & 232) , or a 1961 (models 233 & 234).
...[models 232 and 234 were equipped with electric starters at the factory.]
The 1958 (model 220) had a "rounded" front grille, as compared to the "squared" front grille of the models listed above.
Once you know the model of the tractor and attachments, or the Bolens part numbers for the belts, someone will probably be able to advise what the correct size belt(s) is(are).
#37 dgard OFFLINE
dgard
  • 2 posts
Posted December 13, 2012 - 01:25 PM
Thanks for the replies, it is the tractor in the avatar. It did have an electric start that was removed years ago. The plate with the nos. is hard to read but I will see what i can get from it.
#38 locoman OFFLINE
locoman
  • 7 Thanks
  • 12 posts
Posted December 20, 2012 - 01:57 PM
I was wondering if it is better to get a 43 inch belt or 42 inch belt for the pto? I am having trouble finding a 42 and1/2 belt. Any information on this matter will be greatly usefull. Thanks
#39 Hydrotrack OFFLINE
Hydrotrack
  • 1 Thanks
  • 6 posts
Posted June 09, 2013 - 11:05 AM
Here is a list I have made of Bolens belt numbers, for a quick and easy reference for people looking up their Belt #'s. More will be added to the list as I get time....
[/B]Please Note the sizes Given are to Bolens Specifications, Not all Bolens belts will crossreference to an aftermarket belt as Bolens tended to use odd sizes and odd grooves on their Belts.
Bolens 600: Drive Belt , Bolens Part# 1713716 , 35'' Special.
PTO Belt, Bolens part # 1713714
Starter Belt , Bolens part # 1713533 , 33-7/16''
Bolens 650 & Bolens 750: Drive Belt, Bolens part # 1713716 , 35''
PTO Belt, Bolens part # 1713714 , 43''
Bolens 800, 850 and 900: Drive Belt (for high and low range) , Bolens part # 1720718 34''
OR: part #1715006
OR,OREGON Kevlar Belt # 75-534 , 5/8''X34''
PTO Belt, Bolens part # 1714556 , 42-7/8''
Bolens 850: Drive belt,(high and low range) Bolens pat# 1715006
PTO Belt, Bolens part# 1715740
Bolens 853: Drive Belt (high and low range) Bolens part# 1722072
PTO Belt, Bolens part# 1722095
Bolens 1000 & Bolens 1050& Bolens 1053 & Bolens 1054& Bolens 1220& 1225& Bolens 1253&1254& 1256 & Bolens G-14: Drivebelt, Bolens part# 1716571 34'' (match set)
PTO Belt: Bolens Part # 1716570 42-1/2'' (match set)
[B]Bolens G-9, G-10, G-11, G-12
, Drive Belt, Bolens part# 1725469,
PTO Belt 43'': Bolens part # 1725603
Can someone tell me what size or number belt I need for my 1886. I need the belt that goes to the hydro pump for loader.
Thanks
#40 Hydrotrack OFFLINE
Hydrotrack
  • 1 Thanks
  • 6 posts
Posted June 09, 2013 - 11:12 AM
Hi all,
Need a little help.... I am trying to find out what size belt I need for my 1886. Looking for the hydro pump belt size and number.
Thanks
#41 Bolens 1000 ONLINE
  • 15,461 Thanks
  • 18,291 posts
Posted June 09, 2013 - 08:12 PM
You may want to check with member wilberj
I believe he has a loader on one of his 1886 and could possibly tell you the correct size to get.
#42 Gutkowski OFFLINE
Gutkowski
  • 44 Thanks
  • 58 posts
Posted October 23, 2013 - 09:20 PM
Does anyone have the new part numbers for all the 1050 belts that are needed ?
#43 Gutkowski OFFLINE
Gutkowski
  • 44 Thanks
  • 58 posts
Posted October 25, 2013 - 10:04 PM
Ok just got a catalog from Primelinepe.com and they have Belts for Bolens with Kevlar see attached for sizes and part numbers
#44 Bolens 1000 ONLINE
  • 15,461 Thanks
  • 18,291 posts
Posted October 26, 2013 - 07:06 AM
You can find them on ebay if you type in the part numbers
Starter 1714690
Drive 1736259
PTO 1716570
  • gbrown and Gutkowski have said thanks
#45 Bolens 1000 ONLINE
  • 15,461 Thanks
  • 18,291 posts
Posted October 26, 2013 - 07:08 AM
One thing to keep in mind is there are often many errors in the aftermarket catalogs since Bolens used special size belts many of these company's just used the closest size which does not always work.
  • Gutkowski said thank you
