* * * * * 2 votes
Bolens Belt Sizes
80 replies to this topic
#1 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted June 19, 2010 - 09:22 PM
Here is a list I have made of Bolens belt numbers, for a quick and easy reference for people looking up their Belt #'s. More will be added to the list as I get time....
Please Note the sizes Given are to Bolens Specifications,
Bolens 600: Drive Belt , Bolens Part# 1713716    PTO Belt, Bolens part # 1713714
Starter Belt , Bolens part # 1713533 , 33-7/16''
Bolens 650 & Bolens 750: Drive Belt, Bolens part # 1713716
Bolens 800, 850 and 900: Drive Belt (for high and low range) , Bolens part # 1720718
OR: part #1715006
PTO Belt, Bolens part # 1714556 , 42-7/8''
Bolens 850: Drive belt,(high and low range) Bolens pat# 1715006
PTO Belt, Bolens part# 1715740
Bolens 853: Drive Belt (high and low range) Bolens part# 1722072
PTO Belt, Bolens part# 1722095
Gear Driven Tubeframes: W/ Dual Belt Drive pulleys
Drive Belts 1716571 & 1736259   PTO (42.5'') 1716570
Bolens G-9, G-10, G-11, G-12
, Drive Belt, Bolens part# 1725469,
PTO Belt : Bolens part # 1725603
Edited by Bolens 1000, April 01, 2014 - 09:23 AM.
Updated Belt Reference
  • tractorman604, Aussiedog, sodisr and 6 others have said thanks
#2 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted June 20, 2010 - 06:05 AM
you have pretty good timing i was just thinking about belts im going to put a new clutch in the 1220 soon and figure ill do the belts while its apart
#3 grand OFFLINE
grand
  • 1,987 Thanks
  • 1,996 posts
Posted June 20, 2010 - 06:57 PM
Thanks for the great information! It will be very helpful when we do the updates on the tractors.
#4 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted November 23, 2010 - 01:58 PM
Have you tried Fenner drives? They are not cheap but they are an excellent product. You can make them into any size and really reduce vibration.
  • Bolens 1000 said thank you
#5 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted February 04, 2011 - 08:14 AM
I have edited the list and have taken off the Gates Belt numbers as there was an error in the Gates Matches.
If you have any questions about belts/ sizes part #'s not on the list Let me know.
  • blueridge80 and hatedge have said thanks
#6 I use 1220 OFFLINE
I use 1220
  • 4 posts
Posted July 14, 2011 - 03:15 PM
I recently purchased the correct size FHP belts for my 1220 from NAPA. They even had a parts book that showed correct belts for the entire Bolens line of Tube Frame tractors.
The drive belt p/n is 4L340W.
Less than $20.00 for the pair.
I share this here because I know we have Bolens users out here in the west and sometimes you need to get your tractor back to work and can't wait 3-5 days to get something for your tractor out of the mid-west.
#7 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted July 14, 2011 - 03:38 PM
The only problem with FHP belts is they are "Fractional Horse power Belts" which means they are not power rated. I originally used these belts and had them last me about 3 months before they blew apart.
  • logmillingman said thank you
#8 I use 1220 OFFLINE
I use 1220
  • 4 posts
Posted July 14, 2011 - 09:48 PM
I don't usually have the fancy "matched set" belts last more than one season. I thought I would try these since they were listed at my local parts store as a recommended alternative.
If mine blow apart in three months, I will share it here.
#9 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted July 15, 2011 - 05:02 AM
Seems like some have good luck with them and others dont. Keep us updated on the belts
Got any pictures of your Bolens? :wewantpics: :
What brand did you get the matched sets in? Did you get the kevlar belts?
#10 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 30, 2011 - 09:14 PM
Ok. i have a belt question???? Do we have any list for belts on the walking tractor?? You have posted a nice list of 4 wheeler belts, but it looks like one would need to have a manual for the parts numbers to get a belt. Is there any place that could just say...the 12bb used X xXX belt at the drive pully or this size for the mower, blower and etc.
Its a real pain to measure the pulleys, then goes to the store get 3 differnt sized belts, take them home, then go back to the store with 2 of them because they didnt fit. Im sure lots of guys have been there on this .
#11 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted August 31, 2011 - 05:12 AM
Thats a Good Idea
I will look into to this and see what info I have.
If anyone already has some belt info, feel free to make a new thread and then it can be added as a sticky later
#12 themayor70 OFFLINE
themayor70
  • 4 Thanks
  • 12 posts
Posted March 09, 2012 - 04:13 PM
I read on this thread that the drive belts for the 1256 and the 1050, which I have, were 34 inch length so I bought 4 blue kevlar belts and they are too long, ordered them online and can't return them.. I think I need the 1/2 x 30 and I think it's the same size for both the 1050 and the 1256 but I'd like to know for sure before I buy 4 more belts, but more important, wanted to give you a heads up that they aren't 34 inch so you don't buy the wrong ones.
#13 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted March 09, 2012 - 04:58 PM
The Bolens drive belts are indeed 34'' in length....
I think the place you may have got them from may have given you the wrong size...
What brand of kevlar belts are these?
  • themayor70 said thank you
#14 themayor70 OFFLINE
themayor70
  • 4 Thanks
  • 12 posts
Posted March 09, 2012 - 05:25 PM
I got them from Northern Tool, Pix blue kevlar and it says 1/2 x 34 right on the belts too and the belts I took off my 1256 are noticably smaller, and I found one place on the internet a little bit ago that said the drive belts were 1/2 x 30 and that seems more like it but I wanted to make sure before I bought any more. Not 100% if they will work on my 1050 but I think they might. I also bought a couple of 42 inch for the pto and they are ok.. sure has me puzzeled and I am very new to the garden tractor hobby.
#15 Bolens 1000 OFFLINE
  • 14,935 Thanks
  • 18,114 posts
Posted March 09, 2012 - 05:40 PM
The Belts definitely are 34'' I have a belt measuring tool and Measured a set of NOS Ones I have and they are 34''
What makes you believe the belts you bought are too long? Is your Idler spring possibly worn out? Do you have the original engine mounts in place? confuse.gif
