Started Working On The Bush Hog Hd-12
bush hog hd-12 wisconsin hydro
229 replies to this topic
#136 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 27, 2013 - 07:11 PM
Here are the pics I mentioned in the previous post.
Sent from my SCH-I535 using Tapatalk 2
#137 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 27, 2013 - 07:13 PM
Do you have a part number? Is it s-3035?
Edited by sacsr, March 27, 2013 - 07:14 PM.
  • NUTNDUN said thank you
#138 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:14 PM
George, I'm thinking maybe if you got some heavy aluminum foil and worked it smooth to fit the shape of the reflector, then lift it off and put glue under it, that it would last a long time & give decent reflectivity???
#139 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:16 PM
George, that's just a std machinery type bearing you can get at any farm supply store.  There was supposed to be a lock ring on that eccentric extension to prevent it spinning on the shaft.
#140 NUTNDUN OFFLINE
  • 10,350 Thanks
Which part Scott?
  • sacsr said thank you
#141 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 27, 2013 - 07:17 PM
George, that's just a std machinery type bearing you can get at any farm supply store.  here was supposed to be a lock ring on that eccentric extension to prevent it spinning on the shaft.
I do have the lock ring but it wasn't even up against the bearing to lock it in place.
#142 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted March 27, 2013 - 07:28 PM
Which part Scott?
The shaft
#143 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:31 PM
Just a thought George, but IF there is room nearer the pulley in the pic, you could simply make bushings for the bolts, get longer grade 8 bolts, then offset the mounting spot for the bearing, putting the bearing on good shaft.
  • NUTNDUN and sacsr have said thanks
#144 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 27, 2013 - 07:39 PM
The shaft
I don't know what the part number is. I will try and see if I can find any info on it.
#145 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 27, 2013 - 07:40 PM
That would probably work and it wouldn't be too noticeable either because of the guard that surrounds that upper shaft.
#146 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:43 PM
That's why I get paid the big bucks George!  Wait a minute.....I'm broke all the time!  Something isn't adding up here!  :D
#147 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 27, 2013 - 07:48 PM
It's them moo cows raiding your mailbox on paydays :D
#148 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:50 PM
That would be the feed company taking all the money....and the fertilize company, and the fuel companies, and................
#149 NUTNDUN OFFLINE
  • 10,350 Thanks
I think I might be able to mount the bearing on the inside of the back plate which would offset it enough to put it on a good spot of the shaft. I will go to TSC and get a bearing for it. I will also pull the filter off. It looks like it might be a Fram they have on there now because it is orange. Do these get regular 20w-50 like the Masseys?
#150 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted March 27, 2013 - 07:52 PM
No, calls for type A tranny fluid, but I use Dexron III in them & it does fine.
Also tagged with one or more of these keywords: bush hog, hd-12, wisconsin, hydro
