I Made A Pair Of Wheel Weights Today
38 replies to this topic
#31 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 10, 2012 - 11:04 PM
Alan, do I hear whining and complaining as it relates to a tractor project?? LOL
#32 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 10, 2012 - 11:41 PM
I don't think even your "extra special, whiz-bang, perfectly sharpened, have to sign them out to use one" drill bits would survive drilling thru those rotors. They were case hardened from the brakes dragging or something. And the heat dispersion properties made them a "B" to burn thru.
Yeah, cast iron doesn't burn well with a cutting torch. Most people use carbon rods and compressed air with an arc welding machine. It isn't easy even then. Drilling and sawing works a lot faster and easier.
#33 Acableguy06 OFFLINE
Acableguy06
  • 8 Thanks
  • 21 posts
Posted April 14, 2012 - 07:49 AM
Thats a great way to re purpose something old. Looks nice too!
  • chris m said thank you
#34 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted April 14, 2012 - 08:03 AM
Great looking weights Chris! If you took the cover plate off, laid a block plate over the inner rotor's bolt holes, then you could pour in molten lead to bring these weights to likely 60lb+ each. Slip cover back on & done.
#35 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted April 14, 2012 - 10:21 AM
hi chris m . have you also thought about filling the inner tubes with water.we used to do this on the farm with big tractors.
#36 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 14, 2012 - 11:45 AM
I have thought about it. I Just did this project just for the fun of it lol. I was in welding and fabrication mode and I just couldn't stop making things that day. :laughingteeth:
  • john webster said thank you
#37 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted April 14, 2012 - 01:09 PM
hi. i have had those days two,you cannot beat them, makes the mind work harder.
#38 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 14, 2012 - 02:14 PM
I just thought of something. I can use them right off the car on the Springfield. First, the valve stem is on the back of the rim. Second, I have three bolt hubs, that leaves exactly two bolt lug holes left in the rim, 7/16 but that would still hold them on. Who has a couple more Ford Explorer brake rotors laying around?
#39 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted April 14, 2012 - 11:10 PM
Nice weights Chris. You can always fill the center with concrete or if you have it lead like Kenny did. You can also go the the scrap yard and find some more the same size. Cut the center out and slide the rotor disk over the center and tack weld it in place. Good job.
