2003 Gt 5000 Possible Blown Head Gasket
28 replies to this topic
#16 olcowhand ONLINE
  • 41,037 Thanks
  • 31,384 posts
Posted April 30, 2012 - 02:37 PM
It's a bad design having the gasket that width, but then next to that passage, only little more than half of the gasket actually seals. :(
#17 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted April 30, 2012 - 03:06 PM
I agree. A little more clean up work and it will be ready to button back up for now.
#18 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted April 30, 2012 - 03:32 PM
Have you thought about making a gasket out of thin copper sheet. About 15 years ago I wanted to lower the head on my Gravely engine without doing irreversible changes. I looked at the gasket and decided that a .010 sheet of copper might do the trick. I traced the gasket and cut it out. Been using that gasket ever since with no problems. It's metal, so I don't expect a blowout, and it's copper, so it doesn't block heat transfer either. And no, I never did decide if I got any extra power out of that engine, but it's still running strong.
#19 olcowhand ONLINE
  • 41,037 Thanks
  • 31,384 posts
Posted April 30, 2012 - 04:51 PM
Oh but Chuck has a fix for his problem in the works. I won't say anything more! :orangecool:
  • Chuck_050382 said thank you
#20 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted April 30, 2012 - 05:13 PM
A diesel repower! Now that would be cool!
Geno
#21 olcowhand ONLINE
  • 41,037 Thanks
  • 31,384 posts
Posted April 30, 2012 - 06:06 PM
Geno
Well....sort of! :smilewink:
#22 MH81 OFFLINE
Posted May 08, 2012 - 04:35 PM
Wondering how things are working for you...
#23 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted May 09, 2012 - 07:11 AM
Still haven't made it back out there to mess with it any. We went camping over the weekend so that took a day of prep and a few days to unpack. Hopefully after the kids go to bed tonight I'll get a little shop time. My grass is getting tall...
#24 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted May 24, 2012 - 06:51 AM
Head and blocked checked out flat. Put new gasket and head back on, Got as far as putting the valve covers back on before I had to stop for the night.
#25 MH81 OFFLINE
Posted May 24, 2012 - 06:56 AM
Good luck.
#26 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted May 29, 2012 - 01:20 PM
Got it all back together over the weekend. I only ran it a little but it runs good with no smoke. I am going to change the oil and get the mower deck back on. While it was broke down I cleaned up the underside of the mower deck and gave it a fresh coat of paint.
Edited by Chuck_050382, May 29, 2012 - 01:21 PM.
#27 MH81 OFFLINE
Posted May 29, 2012 - 06:29 PM
Looks good, there was mention earlier of a resolution you had in the works so this doesn't happen again. Did that go by the wayside?
#28 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted May 30, 2012 - 06:30 AM
That venture has been put on hold for a little while.
#29 EricFromPa ONLINE
EricFromPa
  • 3,648 Thanks
  • 3,109 posts
Posted June 13, 2012 - 12:12 PM
You can Hot torque the head if it's only slightly warped.Start her up and get it good and hot and torque it.The gasket will flatten out a bit so you will have to re-set your valve clearances.
I've hot torqued OHV Briggs engines that kept blowing gaskets between the push rod channel and cylinder.
Edited by EricFromPa, June 13, 2012 - 12:14 PM.
