Blade Lift Bar/link?
6 replies to this topic
#1 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted April 08, 2012 - 11:45 AM
Have late model Plastic Kings and need a lift bar/link for same. maybe metal tractors have it if 81 or newer? Is 3/4 to 1" pipe with two U-shaped yokes on it. Both ends have yoke with bolt or pin holes. Might even have slight bend in it. Anyone have an extra to sell? I might have old fashioned one with the spring on one end to trade, but it has been lengthened I guess, not stock. Don't have that yet, future aquisition.
#2 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted April 22, 2012 - 02:12 AM
is this the bar you are refering to? if so i don't have forsale but i can get you any measurments you need.
#3 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted May 02, 2012 - 09:53 PM
Yeah JL, that is it! Some even have a slight bend in them to clear an item under frame on later models. OK, if you can measure that might be good. Measure the plain center rod, then center to center on the yokes, length of yokes, and size of stock used for them, size of big holes in ends. Thanks. Wanna post that here or can email me or private message.
#4 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted May 05, 2012 - 08:52 PM
i'll get the measurement and try to post them tomorrow . ive been getting things i line to get ankle replacement surgery so havn't been online much sorry about the long wait
#5 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted May 06, 2012 - 06:42 PM
gl the rod is 3/4 and yokes are made of 1/4 . the rod is 23 inches long between yokes but a 3/4 hole in each yoke for rod make it 23 and 1/2 due yoke thickness . yokes are 41/8 inches long the hole is 1/2inch and is 1/2 inch from the end of yoke . the width of yoke are 1 1/2 inch tapered down to 1 inch on outer measurements inner is 1 inch tapered down to 1/2 inch. overall lenght is 31 1/4 inches.hole in yokes are 30 1/4 inches from center to center . let me know if you need more than that.0506121914.jpg 0506121914a.jpg
Edited by jlpowell, May 07, 2012 - 05:02 AM.
#6 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted May 11, 2012 - 07:07 AM
JD, that's really good. That will work and allow me to maybe make one. Not sure I can get that crazy bend in the yokes, but can make squarish one's work I believe. Thanks for that info!
#7 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted May 13, 2012 - 12:38 PM
you are welcome . let me know how it turns out. confined to the recliner for next 6 week after ankle replacement . i get to keep up with everything on gtt
