Jd 318 Smoking And Oil To Use?
5 replies to this topic
#1 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted April 07, 2012 - 03:53 PM
My 318 b43g always smoked at startup, but now I see it when the front PTO is engaged. I have Mobile synthetic 10w-30 in it now. I was going to switch to straight 30w or 40w in synthetic if I can find it, but probably dino oil. I am trying to push the engine till the winter or next winter when I can get a rebuilt b43g. Are my thoughts on the right track? I know my pistons are leaking oil, I had the heads of to decarbon after my carb went super rich. Got a new carb and points. Anyway what do you guys think?
Thank You and happy Easter!
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted April 07, 2012 - 04:06 PM
Amsoil makes a synthetic oil that is rated to replace 30w in air cooled engines if you want to stay with a synthetic. You probably could change back to 30w dino now for the summer and it might reduce your oil consumption.
#3 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted April 08, 2012 - 06:47 PM
Im going with Rotella straight 30w. Also going to give engine "Restore" a try, figured if I can limp along by using it, all the better.
#4 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted April 09, 2012 - 02:24 PM
Well it worked great, she is back to herself again.
  • JDBrian said thank you
#5 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,166 Thanks
  • 1,332 posts
Posted April 09, 2012 - 04:53 PM
Restore is the only "snake oil" product that I have found that works as advertized. I have no idea what's in it or how it works but I have used it in three Ford trucks with over 200,000 miles on them and it made a big difference in all three,
#6 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted April 09, 2012 - 06:26 PM
That's good to know. I'll have to look up this "Restore". I've never heard of it before but it sounds like good stuff.
