* * * * - 22 votes
11017 replies to this topic
#10441 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted February 08, 2018 - 02:03 PM
Well, it doesn't hurt to take it east for a bit. Sorry foe the loss of a good neighbor.
  • olcowhand, Craig. and KennyP have said thanks
#10442 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 08, 2018 - 05:09 PM
Dadgummit...the Massey hood retainers ARE not correct!  Smaller than what are in it, but I couldn't see them in their non-clear packaging.  Now another 100 mile round trip, but I'll call first with my tractor serial number to see if he can find the correct ones and get them in before I go back.  I'm gonna do some online checking too.
  I did get the ROPS bar painted and back on the tractor, but that's about it.
Getting ready for the visitation in a few minutes.
  • Texas Deere and Horse, Craig., KennyP and 2 others have said thanks
#10443 Craig. ONLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 943 posts
Posted February 08, 2018 - 09:15 PM
Daniel, was Wondering, how difficult would it be, to build a steel replacement hood, for fiberglass hoods on John Deere GT's? Several individuals in our extended familys have thies hoods and there all busted one way or another. They can't replace them because there to expencive. ( Working midnights up in my Crane, my mind wonders lol)
Edited by Craig., February 08, 2018 - 09:16 PM.
  • KennyP, oldedeeres and Mark 149 J. have said thanks
#10444 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 08, 2018 - 09:19 PM
I'd say pretty difficult.  Not really worth the trouble in my opinion.  Besides, lots easier doing engine maintenance with the hood out of the way!  It's a shame so much cheesy plastic is used on tractors these days.
  • Craig., KennyP and Cvans have said thanks
#10445 Cvans OFFLINE
  • 7,293 Thanks
  • 6,380 posts
Posted February 08, 2018 - 09:26 PM
You sure got that right. Not just the small tractors either.
  • olcowhand, Texas Deere and Horse, Craig. and 1 other said thanks
#10446 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted February 08, 2018 - 09:36 PM
I have repaired two different neighbors JD hoods (a 214 and a 322) by using a fiberglass repair kit. One was a chipped corner, used mat on the inside and overbuilt the outside in layers of resin, the sanded smooth and painted. The other was a crack lengthwise along one edge. Bent metal strips to the shape of corner across, then glued the metal to the hood. Filled the crack with resin and troweled it smooth. Lots of sanding later, primed and painted.
The lengthwise crack is still holding after almost 10 years. The 214's chipped corner busted out a year later when he got a low tree branch. He hasn't bothered to repair it a second time.
  • olcowhand, Texas Deere and Horse, Craig. and 2 others have said thanks
#10447 UncleWillie ONLINE
  • 16,257 Thanks
  • 8,974 posts
Posted February 08, 2018 - 10:24 PM
Buy a sheet of stainless steel and grab a big hammer....
  • olcowhand, Craig., KennyP and 2 others have said thanks
#10448 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 09, 2018 - 10:29 AM
Yes, the fiberglass hoods of old are pretty easy to repair, but I believe Craig is speaking of the newer JD mow tractors with pure plastic hoods.
  • Craig., KennyP, Cat385B and 1 other said thanks
#10449 SimplyRad OFFLINE
SimplyRad
  • 1,293 Thanks
  • 940 posts
Posted February 09, 2018 - 12:49 PM
Has anyone tried a plastic welder on the hoods?
  • Craig. said thank you
#10450 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 09, 2018 - 03:51 PM
Got half of the frame extensions welded in place.  It is made of two 3" plates welded staggered over one another to give 5/8" sticking up of one 1/2" plate for the forks to hook and slide on.  This thing is starting to get heavy, but fortunately I only have to flip it over which isn't too painful.  I'm going back to the shop in a few minutes and cut out the other 4 pieces to do the other side.  Supposed to rain most of the weekend, so I should get a lot of this done.  It'll slow me way down building the mounting brackets though.  Once each side is complete, I'll be cutting back the cross ties so I can split a full length piece of metal into halves so I can weld a 1 1/2" backer to eash side to prevent any possible bending.
Steve had dropped off a car belonging to one of his workers that was bucking at 50mph.  He said it was a 96 or 97, but it's a 95 with OBD1 and my reader is OBD2.  I tried jumping terminals to retrieve the codes manually, but didn't get anything.  So I called him and left it on his voicemail that it's best he took it where they had a scanner to fit, or otherwise I'd just have to start throwing parts at it, which I do not want to do.
  • Craig., KennyP, Cvans and 3 others have said thanks
#10451 Cvans OFFLINE
  • 7,293 Thanks
  • 6,380 posts
Posted February 09, 2018 - 05:25 PM
That is really nice to hear.
  • olcowhand and Craig. have said thanks
#10452 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 09, 2018 - 06:38 PM
I ended up getting 3 of the 4 extension plates for the other side welded in, cut off the roller pins, and split the 42" of flat stock for the rear stiffener.  I also cut back the cross pieces to allow for the stiffener.  Tomorrow should show a lot more progress I hope.  All depends on how I feel, but figure I can work slow & steady like the proverbial turtle.
  • Craig., KennyP, EricR and 2 others have said thanks
#10453 KennyP ONLINE
  • 40,928 Thanks
  • 47,123 posts
Posted February 09, 2018 - 06:48 PM
I know what you mean! Nothing 'Fast & Furious' here!
  • olcowhand, Craig. and oldedeeres have said thanks
#10454 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 09, 2018 - 07:04 PM
Yes, my fast & furious days are sadly behind me!  I am adjusting though.
  • Craig. and KennyP have said thanks
#10455 KennyP ONLINE
  • 40,928 Thanks
  • 47,123 posts
Posted February 09, 2018 - 07:10 PM
I've been 'adjusting' right along! If I don't get it done today, there's always tomorrow, God willing and the creeks don't rise! Gives me more time to think things through!
  • olcowhand, Craig., Cvans and 1 other said thanks
