Daniel, you may want to rethink having the post that close to the wall. Leave a gap there so you can walk around it, get doors open, ect. I think you'll find it will be handier. Is the drive in door in line with the lift?
#8386
ONLINE
Posted September 25, 2016 - 12:01 PM
- olcowhand, Craig. and KennyP have said thanks
#8387
ONLINE
Posted September 25, 2016 - 12:07 PM
No choice, as the left side will be up against the ceiling, so the right side is as far as the left will allow. There is a top rail which attaches to each upright. There may be "squeeze through" room, but not sure just yet.
- Craig. and KennyP have said thanks
#8388
OFFLINE
Posted September 25, 2016 - 12:23 PM
No choice, as the left side will be up against the ceiling, so the right side as far as the left will allow. There is a top rail which attaches to each upright. There may be "squeeze through" room, but not sure just yet.
Might be time to diet so you can squeeze thru.
#8389
OFFLINE
Posted September 25, 2016 - 03:02 PM
May want to think a bit before attaching. You will need to get to that side to set up the lift under the vehicle!
- Craig. and UncleWillie have said thanks
#8390
OFFLINE
Posted September 25, 2016 - 03:06 PM
And doing brake work will require turning the vehicle around.
Would it be possible to notch out the ceiling and move ti over a bit.
Edited by UncleWillie, September 25, 2016 - 03:07 PM.
- Craig. said thank you
#8391
ONLINE
Posted September 25, 2016 - 04:13 PM
- Texas Deere and Horse, Craig. and KennyP have said thanks
#8392
OFFLINE
Posted September 25, 2016 - 04:45 PM
Sounds like a good bit of room!
- olcowhand and Craig. have said thanks
#8393
ONLINE
Posted September 25, 2016 - 06:59 PM
All about perspective
#8394
OFFLINE
Posted September 25, 2016 - 08:12 PM
Eric
#8395
ONLINE
Posted September 25, 2016 - 08:36 PM
Width between columns is 9 1/2 feet. My truck not including the mirrors is only 6 1/2 feet, so plenty of room. I haven't drilled any mount holes yet. Instead I spent most of the evening just reading the installation manual & getting familiar with it all. I have the main column plumb. I have to get it mounted first, then connect the cross-over before mounting the other column to the floor. Nothing to get in a hurry about as I need it right.
Lowes only had Bosch masonry bits in 3/4". I bought 2 just in case, but if not needed I'll take the extra one back. $20 each.
- Texas Deere and Horse, Craig., KennyP and 2 others have said thanks
#8396
OFFLINE
Posted September 25, 2016 - 09:04 PM
#8397
ONLINE
Posted September 25, 2016 - 09:13 PM
Just curious, how thick is the slab there?
It's around 7+" there. I planned ahead & made sure it was plenty thick where I might put a lift. I will also be adding brackets at the top to bolt into the trusses for a very strong setup. I've seen pics of 2 post failures, and want mine bulletproof!
- Craig., KennyP and Sawdust have said thanks
#8398
ONLINE
Posted September 25, 2016 - 09:20 PM
Oh, and my concrete is a 5,000psi mix with 1/4" steel mesh reinforcement throughout (hope the mesh doesn't cause me drilling issues). My lift papers say only 4 1/2" of 3,000psi mix is all required, but much better safe than sorry!
- Alc, Craig., KennyP and 1 other said thanks
#8399
ONLINE
Posted September 25, 2016 - 09:28 PM
Ouch! That's a big part of why I like the Ryobi bits, I think Home Depot carries them, been a while since I've needed one.
#8400
ONLINE
Posted September 26, 2016 - 06:56 AM
- olcowhand, Craig. and SupplySergeant have said thanks
