* * * * - 22 votes
11017 replies to this topic
#6781 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 29, 2015 - 04:10 PM
Been working on the Onan going into the Caddigger.  Took the intake & exhaust off so I could check valve lash.  Very little change since the rebuild, but tweaked the intake valves just .001" each.   Took carb top off and inside was clean as a whistle.  Put the carb & intake back on.  I also welded the new sprocket/hub together.  Almost surely have to cut the crank short so there will be room behind the engine pump adapter for the crank to pump shaft adapter.  My engine/pump adapter won't be in till Friday the soonest, so I'll work on other things till then.
 I also cleaned up the points & set static timing.
  • Alc, Texas Deere and Horse, Craig. and 1 other said thanks
#6782 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 29, 2015 - 04:45 PM
Glad you had the time to check it out.
#6783 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 944 posts
Posted November 29, 2015 - 07:01 PM
The only thing I didn't like about the Onan, was the way they mounted the air filter to the carburetor, the screws would come loose and go down into the engine. Happened to me probably about 3 or 4 times. Time the use the blue or red to make sure they don't come out lol
Edited by Craig., November 29, 2015 - 07:02 PM.
#6784 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 29, 2015 - 07:04 PM
I made up a piece of window screen to cover mine! Needs to be bowed up some to clear the choke!
  • Texas Deere and Horse, Craig. and toomanytoys84 have said thanks
#6785 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 944 posts
Posted November 29, 2015 - 07:15 PM
That's a good idea never thought of that
#6786 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 30, 2015 - 08:14 AM
Wow....my engine pump mount will be delivered today, as it shows it arrived at my local post office early this morning!  Was estimated for Friday.  I should have it all running by end of the week now.
  • Texas Deere and Horse, Craig., KennyP and 1 other said thanks
#6787 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 30, 2015 - 08:28 AM
That's great news!
  • Craig. said thank you
#6788 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 30, 2015 - 09:00 AM
Got my silage fed to the heifers, and shop is heated up.  Going to do some wiring today.  The Teledyne had it's own ignition, so the battery just cranked it over.  This one will have a charging system and needs it, as the coil is battery powered, plus it will have an electric fuel pump. I had a bracket for 3 gauges, but welded a plate over the center, then bored a hole for the key switch.  To each side will be a gauge, one ammeter, the other oil pressure.  I need to weld on a plate where the voltage regulator, electric fuel pump, and starter solenoid will mount.
#6789 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 30, 2015 - 09:25 AM
Sounds like you have a good plan going!
  • olcowhand and Craig. have said thanks
#6790 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 30, 2015 - 12:35 PM
Got the wiring finished except the wires need to be cut to length that go to the engine stator & coil.  I'll cut them to proper length once engine is set in.  I need to scrounge up some wire loom or buy more.
  I was going to connect the tubing to the gauge end, but seen this kit just came with 5' of tubing, which isn't enough.
The electric fuel pump will mount on this plate as well, but a friend borrowed it to test his tractor and I need to go pick it up.  He's finished with it, so I'll get it then drill mounting holes.
  • Texas Deere and Horse, Craig. and KennyP have said thanks
#6791 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 30, 2015 - 01:09 PM
Looks real good, Daniel!
#6792 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 944 posts
Posted November 30, 2015 - 05:06 PM
After all that work are you going to give it a nice coat of paint? Lol
  • olcowhand said thank you
#6793 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 30, 2015 - 05:23 PM
That crossed my mind, but not anytime soon.
I'm still down at the shop, but spent a lot of the afternoon straightening things up. Neck has been aching today so took a pain pill, and they slow me down. I usually need only one pain pill every week or 2.
#6794 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 944 posts
Posted November 30, 2015 - 05:31 PM
You're taking one pill every week or two, that's great you could do that forever unlike me when I was taking 4 a day got hooked on them stupid things. I'll never do that again
#6795 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted November 30, 2015 - 05:36 PM
Yeah I only take one if I really need it. Today was the day. They last 8 hours, so one gets me through a work day. I'm fixing to call today's work done.
