* * * * - 22 votes
10318 replies to this topic
#6001 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 01, 2015 - 01:48 PM
Started this morning on the new corral fence.  Got 3 sections up, which is plenty for now so I can put up the fly rubs.  I also did some welding on the auto head locks and it still needs more work later.
  Then I did some work greasing the discbine.  Can't find the manual, so downloaded a user's manual, and I found 2 grease zerks we never remember greasing!  Found some other info which may be partly why rocks have been giving us issues.  A couple adjustment procedures haven't been done that I know of and I know those header float springs have surely sagged in close to 15 years.
  Started raining at noon & just came another flood a few minutes ago.
I decided just to use a single fly rubber here, so at the far end I'll put a 16' gate across and hang the fly rub at the gate opening at the front of the pic.
  • grnspot110, Craig. and KennyP have said thanks
#6002 KennyP ONLINE
  • 37,511 Thanks
  • 45,514 posts
Posted July 01, 2015 - 04:10 PM
Ain't it just the berries. Use a piece of equipment that long and find new things to grease!
  • olcowhand and Craig. have said thanks
#6003 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 01, 2015 - 04:54 PM
Did I miss something?  Are you going into the cattle business?
When all else fails read the directions!  :poke:  :smilewink:
  • olcowhand, Craig. and KennyP have said thanks
#6004 KennyP ONLINE
  • 37,511 Thanks
  • 45,514 posts
Posted July 01, 2015 - 05:08 PM
Daniel kinda knows cows!
#6005 UncleWillie ONLINE
  • 15,535 Thanks
  • 8,710 posts
Posted July 01, 2015 - 07:10 PM
But not in the Biblical sense.
  • MH81 and Craig. have said thanks
#6006 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 02, 2015 - 10:25 AM
Took Dad to Dr today, as he's been feeling short of breath, even though the finger oxygen meter says all is good.  Turns out he has fluid in both lungs, but not pneumonia yet.  Raising his Lasix dosage & all should get better.
  My part for the discbine is IN!  :dancingbanana:  It was a part the books show would replace the back-ordered OE part, so I'm taking my old swivel arm to make darn sure it matches up.  I can finish it in one or 2 days easily, but still rain chances every day through a week's forecast!  When I'll get to make hay I have NO idea!
  • Craig. and KennyP have said thanks
#6007 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted July 02, 2015 - 01:17 PM
We're mowing some this evening, decent forecast here till Monday.
  • Craig. said thank you
#6008 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 02, 2015 - 02:39 PM
I HAVE THE DISCBINE PART!   :dancingbanana: The part was identical, so no idea why it was listed as a "substitute" part.  The OE # was back-ordered but this part is the same thing.  Oh well, I have it.  I'll start on finishing it in the morning unless I feel bad.  Not feeling so great today.  I guess building the new corral fence pulled on the muscles too much as my neck & shoulders are hurting today.  I thought I would be ok, as I tacked in "hanger nails" so I could just sit the 2x10's on them instead of holding them up in place while nailing.  Come to think of it, it's likely swinging the hammer was the culprit.
#6009 KennyP ONLINE
  • 37,511 Thanks
  • 45,514 posts
Posted July 02, 2015 - 04:01 PM
Swinging a hammer uses more muscles than you think! Glad the part was correct!
  • olcowhand, Craig. and UncleWillie have said thanks
#6010 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,645 Thanks
  • 5,842 posts
Posted July 02, 2015 - 09:53 PM
Battery framing nailer!
#6011 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 03, 2015 - 12:23 PM
Heifers finally came up for mineral last night, and like I figured, stopped in their tracks, huddling together talking it over.  Finally after 20 to 30 minutes, one got brave & went on in.  Soon they all joined in.  One loved it and stood rubbing his face & neck for several minutes.  I noticed this morning they weren't swatting their tails nearly as much, so the fly control is already working.  :thumbs:
  • Alc, Craig., KennyP and 2 others have said thanks
#6012 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 03, 2015 - 02:47 PM
:dancingbanana:  :dancingbanana:   The discbine is finished!  Well, kinda.  I need to weld in a gusset plate, but haven't moved the Century welder down here to the new shop yet, and it's been pouring rain on & off all day, so hoping it'll be dry enough to pull it down there tomorrow, or maybe finally move the welder down here.
  Also haven't tested PTO it of course, but everything should be a "go".  I've turned all with a pry bar in the pto, and all feels smooth.
  Now for a few days without rain to make hay, which may not come for over a week.  Forecast has rain chances ever day through next Thursday.  When it stops raining, it likely will get dry as can be.  I hope it will for at least a week!
  All the bends in the shields have nothing to do with me.  Dad has run the thing into all kinds of stuff.  I'm hoping to do all the cutting myself after all this repair.  If it gets broken again, it would be best that I did it. :smilewink:  All the new parts inside and outside that cutter bar totaled about $4,100 and several painful days work.
  • Craig., KennyP, HDWildBill and 1 other said thanks
#6013 Alc ONLINE
  • 6,750 Thanks
  • 7,399 posts
Posted July 03, 2015 - 03:02 PM
Hate to sound stupid but what does the discbine do ? Cut and windrow the hay ?
#6014 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted July 03, 2015 - 03:25 PM
It cuts the hay, the runs the crop between 2 rubber "Chevron" tread rubber rollers to crush the stems to aid in drying.  It will windrow for chopping as haylage, or lay it down in wide flat strips for drying to make baled hay.  Once dry, then you rake into windrows for baling.
  • Alc, Craig., KennyP and 1 other said thanks
#6015 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,057 Thanks
  • 882 posts
Posted July 03, 2015 - 04:03 PM
I can't get over how clean that cutting bar looks, nice job! 👍
  • olcowhand said thank you
