* * * * - 22 votes
10922 replies to this topic
#5071 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted February 20, 2015 - 11:15 AM
Okay! I underestimated a bit! Your temps are way down there. I hope it warms some soon!
  • Craig. said thank you
#5072 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 12:57 PM
Yep, -13F is cold, and without parlor heat..............
Just finished patching the busted water pipe.  The so called "Freeze proof" stock waterer in the dry field was partly frozen.  The ball that floats up & seals the drink opening was frozen in place.  Josh did the usual pouring of hot water, but it still didn't give.   He pushed it with the heel of his boot & cracked the ball, and they aren't foam filled.  Local feed store had a replacement, so Josh went to get it along with 100lbs of salt.  At least tonight it's supposed to only go down to 24, but we'll see.  With a forecast of up to 3" of snow & sleet, with possible freezing rain, the outlook is for no fun over the weekend.  Everything has stopped except for basics with the rest of the time going to problem after problem.  MIL is still in the hospital too, but I've had no time to visit, and Teresa doesn't like to drive on the icy roads.  MIL "may" come home today or tomorrow if her blood oxygen levels improve.  The pneumonia knocked her pretty good.
  • Texas Deere and Horse, Craig., KennyP and 2 others have said thanks
#5073 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted February 20, 2015 - 01:13 PM
Hang in there Daniel, it will get better.
  • olcowhand, Craig. and SupplySergeant have said thanks
#5074 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 01:21 PM
1/4" ice possible tonight, along with sleet & snow.  I may not get the day off tomorrow after all.  If we get freezing rain,it will be nearly impossible to feed silage.  It has to get better one of these days.  :(   I'm being stressed way more than I need to be.  My leg that had the DVT's (blood clots) is bothering me a lot.  Been on my feet way more than usual & feeling it.
  • MH81, Craig., KennyP and 1 other said thanks
#5075 TAHOE OFFLINE
TAHOE
  • 8,167 Thanks
  • 5,759 posts
Posted February 20, 2015 - 03:37 PM
Man, ice is the worst.
We had a high of 17 today, snow starts around midnight, 3-6" ,then afternoon gets in high 30's, maybe break 40 and turn to rain.
I think we will all be happy to get into spring.
  • MH81 and Craig. have said thanks
#5076 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 04:01 PM
Stock waterer is repaired, all the gals in the field came running for a drink.  I fed silage for Josh while he ran to town for the ball, and had him pick up some ice busting salt too.  100lbs, but I should have bought a pallet of the stuff!  Soon time to milk, but tonight should be simple.  Had the furnace running all day long to put some warmth in the concrete, and it feels better in there, but a half hour ago there was still some ice on the floor where the cows walk, so it got some salt.  I'll sand it if it needs it also.
  Had them put me on the list to top off the propane tanks.  Our lowest tank is at 30%, but don't want anything getting low with the unpredictable weather we're having.
#5077 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 04:06 PM
Forgot....found a Dove in the milk parlor this morning.  There was a hole where feed pipes used to enter the parlor that the insulating plug had fell out of, so it must have entered there.  It flew around, then landed on a milk weigh jar right next to me.  I just picked it up.  I took my glove off a couple minutes later & held it to take it outside, but when I opened my hand outside, it just sat there in my hand, happy to be getting warm.  I held it a few minutes while I was trying to run the wash cycle to thaw the milk lines.  By that time I took it out again & it took flight to the barn.  If it had been a starling, I'd have given him flight into concrete!
  • MH81, Texas Deere and Horse, Craig. and 4 others have said thanks
#5078 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 20, 2015 - 04:23 PM
White dove, a sign someone is looking over you?  A sign of peace in your future? You deserve it after all you have been through.
  • olcowhand and Craig. have said thanks
#5079 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 06:49 PM
Made it through milking tonight without issue.  Tired as heck, and hungry.  Bowl of oyster soup coming up!
  Dad's water froze at his house last night, but thawed late this afternoon....and it's busted under his house.  If I remember right, it's 1/2" rigid copper, so if so, I can get a couple shark bites & a piece of pex & fix it easy as sin.  If one end of the copper can move inward just a bit, then all I'll need is one shark bite.  If roads are bad tomorrow, it may have to wait.  BUT, in that case I could solder the repair, as I'm pretty sure I have the copper couplers.
  • Craig., KennyP and HDWildBill have said thanks
#5080 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted February 20, 2015 - 07:00 PM
Coming at you from all directions!
#5081 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 20, 2015 - 08:40 PM
Always is anymore it seems.  Hard to keep up with it all.
#5082 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,118 Thanks
  • 917 posts
Posted February 20, 2015 - 10:13 PM
Ok Unc, the plan now is next Friday. C U Then.
  • olcowhand said thank you
#5083 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted February 21, 2015 - 05:29 AM
Maybe he'll come back today? You could have company while out there!
#5084 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,496 Thanks
  • 6,180 posts
Posted February 21, 2015 - 07:46 AM
Or a sign that Daniel is a Disney princess and didn't know it?
  • olcowhand, Craig. and KennyP have said thanks
#5085 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted February 21, 2015 - 08:28 AM
No phone call this morning, so got over 9 hours sleep!   :dancingbanana:   Looks to be some ice sheet out there, and I hear/see the light rain.
  • Texas Deere and Horse and Craig. have said thanks
