* * * * - 22 votes
10924 replies to this topic
#4351 UncleWillie OFFLINE
  • 16,105 Thanks
  • 8,906 posts
Posted November 24, 2014 - 02:23 PM
At least the blood wasn't so thin it all leaked out when you perforated your hand.
#4352 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted November 24, 2014 - 03:10 PM
Back from the Dr office.  The Dr wasn't in, but they called to give him my INR numbers (blood thinning number), and he reduced my warfarin.  My number was higher than needed, but still in the safe zone. Went to Wally World, Home Depot, then Sam's Club.  So glad to be home.  My feet were hurting me, and my right calf swelled up.  Got my leg hiked high for a while before doing the afternoon feeding.
  • trowel, HDWildBill and SupplySergeant have said thanks
#4353 Craig. ONLINE
Craig.
    Ronald Craig
  • 1,122 Thanks
  • 918 posts
Posted November 24, 2014 - 03:39 PM
Dr. knew about swollen calf??
  • olcowhand said thank you
#4354 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted November 24, 2014 - 05:26 PM
Yep, it's something I have to live with from here on out.  I found out something I never knew....the vessels have check valves to prevent back pressure from building up of fluids.  These check valves provide for positive blood flow, but the blood clots destroy the check valves, so now fluids can back up in the affected area, which is my right calf.  He doesn't want me to wear compression socks just yet, as he feels as active as I am that I will do just as well or better without them.  Time will tell that or not.
  • Craig., trowel and HDWildBill have said thanks
#4355 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted November 24, 2014 - 05:34 PM
Dan - I would not recommend it , but you will find running across a plowed field still possible and enjoyable , eventually .
  • olcowhand and Craig. have said thanks
#4356 Craig. ONLINE
Craig.
    Ronald Craig
  • 1,122 Thanks
  • 918 posts
Posted November 24, 2014 - 05:50 PM
Didn't no any of that, thanks for the info!
#4357 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted November 24, 2014 - 06:18 PM
Glad your hand didn't have any lasting swelling, Daniel. I was kind of worried about that. Get some rest. That shopping can wear a guy out, even when you feel good!
  • olcowhand, Craig. and trowel have said thanks
#4358 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted November 25, 2014 - 03:15 PM
:dancingbanana:  :dancingbanana: I now have my Cat 910 loader back in action!  Picked up the starter today after a total going through.  New brushes, both new relays, new bearings/bushings, starter drive, new oil seal, and the armature pickups turned down smooth.  She spins a lot faster now too!   :thumbs:
  It's a bit of a hassle getting the one bolt back in, but 2 feet of extensions and a crows foot (along with a heavy dose of patience) I got it back in.
  Now to feed in a bit, then call it a day.
  • Texas Deere and Horse, GTTinkerer, Craig. and 3 others have said thanks
#4359 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted November 25, 2014 - 06:42 PM
Is there anything the Dr. can do about putting in some kind of check valve in your veins?
Glad to hear you got the Cat up and running. Now if you could just figure out how to fix our CAT, he's not been right for a long time. :)
  • olcowhand, Bill56, Craig. and 2 others have said thanks
#4360 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted November 25, 2014 - 06:53 PM
There's only one 'fix' i can think for that 'Cat', Brian!
Glad you got the loader going again!
#4361 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted November 25, 2014 - 06:54 PM
Glad you got the 910 starter installed, Daniel. It sure isn't easy working on things that have to go in confined spaces. Like you said... Lots of patience.
#4362 HDWildBill OFFLINE
  • 8,978 Thanks
Posted November 25, 2014 - 10:10 PM
I don't that that would even work Kenny!
Ditto on the loader Daniel.
  • olcowhand, Craig. and KennyP have said thanks
#4363 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted November 26, 2014 - 02:58 PM
Whew...tiring day.  Got the milking done, then started on both water heaters at the milk parlor.  The smaller one has been shut down for a while.  It stayed set at 100F just for washing the cows udders, but wasn't a big deal till cold weather arrived.  First I took out the lower element in the main heater & removed about 4 gallons of mineral deposits.  When the element went out, it also took out the upper thermostat, so it got switched out along with a new lower thermostat also.  Then had problems getting the lower element out of the smaller heater.  Had to bring my small air compressor to the parlor so I could use my air impact gun on it.  It took it right out!
  Another 4 gallons of mineral from this one too, and found the upper thermostat bad in this one too.  Had one left, so gotta go pick up spare thermostats and a couple elements to keep on hand.
  I had to put down both sick little heifers, as there was no hope at all for them to survive.  I was hoping both would pass in the night so I wouldn't have to, but they just kept suffering badly.
  Now for a little break before feeding time.  I worked harder today than I should have I suspect.  Sure doesn't sound like that much work when I type the words, but it has been for me.
  I also called my vascular surgeon who will remove the clot filter.  They made my appointment for Dec 30th to discuss the removal, but my insurance is 15 grand deductible per calendar year.  I asked them if the insurance would consider it an ongoing thing & not apply it to my deductible, but the lady said no, that she needed to move me up closer, so she made it the 18th so I could get it removed before Jan 1.
  • Bill56, GTTinkerer, Craig. and 3 others have said thanks
#4364 HDWildBill OFFLINE
  • 8,978 Thanks
Posted November 26, 2014 - 03:54 PM
I picked up a 1/2" impact driver from HF a while back and that thing is great.  Very seldom do I have to break out my air impact driver.
  • Craig. said thank you
#4365 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted November 26, 2014 - 04:30 PM
Oh, I use mine all the time!  Mine is an expensive one I bought at an auction for just $50.  Ingersol Rand I think it is.  Sure is strong.  Gets things loose that Dad's "Earthquake" can't.
  • Craig. and HDWildBill have said thanks
