* * * * - 22 votes
11017 replies to this topic
#3886 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted September 09, 2014 - 05:22 PM
He's done quite a bit this time.  If he's comfortable with it, he can go ahead.  But if it makes him too nervous, that can't be good.
That's where you need to teach him how to do that! He'll never learn listening to you! Gotta do it!
  • olcowhand and HDWildBill have said thanks
#3887 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 09, 2014 - 07:19 PM
True enough, guess I'm being a mother hen!
  • Craig. and KennyP have said thanks
#3888 DougT ONLINE
DougT
    Dog Approved
  • 7,120 Thanks
  • 5,082 posts
Posted September 09, 2014 - 08:16 PM
I'd be worried if he got up on the pile and he wasn't nervous. Over confidence and lack of experience can be a bad combo.
  • olcowhand, Texas Deere and Horse, KennyP and 1 other said thanks
#3889 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 09, 2014 - 10:13 PM
Daniel
You know from experience that packing a silage pile is harder than it looks. Best if Josh can take his time and learn the right way rather than the hard way.
  • olcowhand, GTTinkerer and KennyP have said thanks
#3890 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 01:16 PM
Well, Josh was doing half decent packing, but we're shut down.  The twin belts that run the reverser transmission gave up the ghost.  They normally stock them at my dealer, but when I stopped by Saturday, they were out.  They should have been in yesterday, but still not there yet today.  One more truck delivery today, otherwise they will surely be in tomorrow, and I'll go get them.  We'll finish chopping Friday I guess.
  Once the new shop gets completed, this chopper goes in this winter for a going over.  Several areas need attention, and I'm not waiting till it's time to chop next year to see to it.
  • Texas Deere and Horse, GTTinkerer, Craig. and 2 others have said thanks
#3891 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 02:58 PM
Had more problems....just not my day.  Went to crank the Cat loader to work down the pit a bit. Nothing...not even a click.  I check the battery & the ground terminal had been hot, and it was loose.  Wiggled it & sparks....key was off!  Had pliers in pocket, so pulled the + cable off battery.  Got to digging & found the main charge wire from alternator to starter had shorted against the block & burned in-two.  It's a wonder it didn't burn to the ground.  While working on the wiring I pulled my Massey 1655 diesel up by it & put my junior jump cables from it to the loader battery to charge it.  After a few minutes the 1655 started to miss.......CRAPS...out of fuel!  Before I could unhook & get took off....she died.  Had to bleed the system after a gallon of fuel.  That's MY fault though.  :wallbanging:   Anyways, all taken care of and pit packed.  We would definitely had finished "Silage 2014" hadn't the belts blew apart.  :(
  • Craig., KennyP and SupplySergeant have said thanks
#3892 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 10, 2014 - 03:40 PM
sounds like an awesome plan.
  • Craig. said thank you
#3893 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 07:23 PM
I think I suffered from dehydration today.  It hit me while building new trailer ramps.  DIZZY every time I stood up, then the last time I thought I was gonna pass out.  I didn't take a jug of water today as it wasn't really hot, but all the signs point to dehydration.  After this hit me, Teresa said she noticed I didn't even drink much at lunch.  Getting older requires modifying what you do to take care of one's self I reckon.  I had dizziness, muscles ached, and severe muscle weakness.  Once I came in, drank fluids, and rested, now I feel almost normal again.  Well, the "new normal" as it's a constantly changing description.  Drinking some Gatorade right now!
  • GTTinkerer, Craig. and EricR have said thanks
#3894 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 07:28 PM
Oh, forgot to post...the 2 ton GMC we haul silage with must have a faulty fuel tank gauge or sender.  I know I have a pickup tube pinhole in the tank, and if it gets much below 1/2 tank, it picks up air & starts dying or at least powering down low before catching again. (another winter repair) Well, it had a bit over a 1/2 tank yesterday, but after it died on Josh today, it read 1/4 part of the time.  So I shot it to town, having it drag down twice on the way, but recovered once I downshifted & kicked up the rpm's.  Then as I turned into Bault Oil, she died completely & I had to double strong arm to steer it, and I coasted to the pump!  Got her filled up, restarted with a burst of starting fluid, and back home to chop, only to chop maybe an hour or so when the chopper belts failed me.  Oh well...I did my best.
  • GTTinkerer and Craig. have said thanks
#3895 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
At work we have 'I Need Grease To Live' stickers on most of the equipment. Do you need a 'I Need Water To Live' t-shirt?
  • olcowhand and Craig. have said thanks
#3896 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 07:30 PM
Seems I definitely need supervision!
#3897 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 10, 2014 - 07:35 PM
sometimes,  a clone would be nice
#3898 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 07:37 PM
Yeah, but likely I'd not get along with (my other) myself well enough!  :smilewink:
#3899 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
Posted September 10, 2014 - 07:38 PM
I got it: Spray paint "Drink Something" on the side of your cows.
:thank_you:  :hitting_self_roller:
  • olcowhand, Craig. and KennyP have said thanks
#3900 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted September 10, 2014 - 07:40 PM
I can cut some decals for all the equipment..... "Got Milk....Water, ...Anything?"
  • DougT, Texas Deere and Horse, Craig. and 3 others have said thanks
