* * * * - 22 votes
10309 replies to this topic
#3856 olcowhand ONLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 02, 2014 - 10:24 AM
 Nix loading junk iron.   I just went to check the fields, and I believe we can chop this afternoon.  Sun is out and ground is setting really good.  Forecast looks good for the next 2 to 3 days!   Maybe, just maybe we'll make some progress chopping.  fingerscrossed.png
  • Texas Deere and Horse, Craig., KennyP and 3 others have said thanks
#3857 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,053 Thanks
  • 879 posts
Posted September 02, 2014 - 10:37 AM
Cool!
#3858 HDWildBill OFFLINE
  • 8,975 Thanks
Hope all goes well. :thumbs:
#3859 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 02, 2014 - 10:40 AM
 Nix loading junk iron.   I just went to check the fields, and I believe we can chop this afternoon.  Sun is out and ground is setting really good.  Forecast looks good for the next 2 to 3 days!   Maybe, just maybe we'll make some progress chopping.  attachicon.giffingerscrossed.png
what % moisture do you shoot for in corn silage.     The dairy farmers up this way like to start around 65% or so.
  • olcowhand and oldedeeres have said thanks
#3860 TAHOE OFFLINE
TAHOE
  • 7,810 Thanks
  • 5,610 posts
Posted September 02, 2014 - 11:25 AM
  Rain all broke up and what was left went to Cincy...I think maybe Marty got spared this rain???
don't think we got any of yours, but radar shows a bunch coming across Indiana. If it comes straight across, we will get more this afternoon.
  • olcowhand said thank you
#3861 olcowhand OFFLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 02, 2014 - 05:11 PM
Ours is around 68% right now, but the grain is past prime for silage, hence my urgency, that and needing the fields finished & prepped for plow day.
  We actually chopped for 4 hours today!  Got many loads hauled, and no major problems.  One field with lots of grass was too wet still & caused balling up around shafts, so I pulled out & went to the other field.  Only issue I had there is I lost a master link off a roller chain.  Had another & was back in business in a matter of 5 minutes.  It did come a heavy 2 or 3 minute rain, but I was determined to finish this field, so I pulled the loads near the farm drive to unload, as Josh got stuck the previous load & I pushed him out with my chopping train. I liked just one pass finishing the field when another 2 minute downpour came through, so called it a day.  Very happy to having made progress this afternoon!
  • Bill56, Craig., KennyP and 2 others have said thanks
#3862 Bill56 ONLINE
  • 839 Thanks
  • 2,179 posts
Posted September 02, 2014 - 06:28 PM
Doesn't sound like too bad of a day,Daniel. Glad you made some progress with the chopping!
  • olcowhand and Craig. have said thanks
#3863 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 04, 2014 - 03:18 PM
Looks like Daniel is having a good day today. This was posted on FB by his neighbor and I copied it and posted it here for everyone.
  • Bill56, Craig. and KennyP have said thanks
#3864 olcowhand ONLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 04, 2014 - 03:21 PM
Yes Brian, the day was a GOOD one chopping & doing other farm stuff.  Only had to get out of the tractor 2 times, and just for 10 seconds each time to beat a piece of tin work back in to keep it from snagging corn.  When I finished I saw why it broke & pooched out.  A bracket had lost a bolt, so this piece was moving up & down till the cheap thin tin broke.  Taken care of while lubing the chopper after calling it a chopping day.  The hardest part of the day so far was after I quit chopping.  The AC in the tractor isn't cold, but keeps the cab comfortable enough.  I sweated buckets while fueling the tractor & lubing the chopper!  Takes about an hour to do it proper.
 Hope tomorrow goes as nice as today!
  • Texas Deere and Horse, GTTinkerer, Craig. and 2 others have said thanks
#3865 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 04, 2014 - 03:27 PM
I hope tomorrow is an even better day then today was. Good to see you chopping in the field for sure. :thumbs:
#3866 olcowhand ONLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 04, 2014 - 03:28 PM
Now I need to go pack the silage a bit, then do the feeding.  Me thinks I'll need a shower tonight!  :smilewink:
  • Craig. said thank you
#3867 KennyP ONLINE
  • 37,398 Thanks
  • 45,452 posts
Posted September 04, 2014 - 04:31 PM
Just take a dip in the stock tank! Teresa may not approve, but you'll feel better!
#3868 olcowhand ONLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 04, 2014 - 06:25 PM
Took my dip in the shower!  Then took Teresa out for some Famous Recipe chicken!  We earned it!  Now once it cools a bit out, I'll go unhook the other Massey 2745 from the discbine so we can pack silage good with it in the morning.  Then it gets the batwing put on it so I can start getting the plow fields in shape as soon as I get time.
#3869 Bill56 ONLINE
  • 839 Thanks
  • 2,179 posts
Posted September 04, 2014 - 06:37 PM
Sounds like a good, productive day Daniel! Glad things are going better with the chopping. Hope you can get some relief from the heat soon.
#3870 olcowhand OFFLINE
  • 40,339 Thanks
  • 31,169 posts
Posted September 04, 2014 - 07:42 PM
Went out just a bit ago to unhook the other 2745 from the discbine, but thought low battery.  Jumped charged it off my diesel MF1655, but after several minutes no difference.  I think it's in my master power cutoff switch, as I turned it on & off a couple times, then she cranked over fast.  Anyway, put a charger on 2 amps overnight just to be sure.  After milking tomorrow evening, I may go batwing some plow day field!
  • Bill56, Texas Deere and Horse, GTTinkerer and 3 others have said thanks
