* * * * - 22 votes
10313 replies to this topic
#2236 KennyP ONLINE
  • 37,463 Thanks
  • 45,484 posts
Posted January 19, 2014 - 05:48 PM
I hope so, Daniel!
  • olcowhand said thank you
#2237 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted January 19, 2014 - 05:53 PM
I hope so, Daniel!
Me too buddy, me too!  If not, I'll keep trying.
  • Craig. and KennyP have said thanks
#2238 UncleWillie ONLINE
  • 15,527 Thanks
  • 8,706 posts
Posted January 19, 2014 - 06:00 PM
I will give you $200 for it.
  • sacsr said thank you
#2239 KennyP ONLINE
  • 37,463 Thanks
  • 45,484 posts
Posted January 19, 2014 - 06:23 PM
Next time it quits, he may take you up on that!
  • oldedeeres said thank you
#2240 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted January 19, 2014 - 07:34 PM
Well, let her cool off a while, then go to start it......she started then died!  Restarted fine after, but issue is still there.  Back to the drawing board.  And Willie....no sale!  :smilewink:   I don't give up easy!
  • KennyP, sacsr and oldedeeres have said thanks
#2241 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted January 19, 2014 - 07:39 PM
Seems the ECM/PCM (computer) tends to have solder issues on the regulator board inside.  They say most of the reman units were rebuilt by simply re-soldering these connections.  I will check my unit as soon as I can, likely tomorrow evening. Bringing Dad home from rehab tomorrow right after morning milking, and I have a ton of other things needing done if I get the time.
  • Craig., KennyP, HowardsMF155 and 1 other said thanks
#2242 HowardsMF155 OFFLINE
  • 2,838 Thanks
  • 2,979 posts
Posted January 19, 2014 - 08:08 PM
Best wishes on getting your Dad home, I know that will mean a lot to him and you both.
#2243 TAHOE ONLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted January 20, 2014 - 10:25 AM
Forgot to post.  When Josh went to scrape the lots & alleys yesterday, he found a cow dead in a stall.  Not hung up in any way, just laying there like resting.  Young 1st calf heifer too, and seemed fit as a fiddle.  This happens now & then without any visible reason.  Likely just dropped dead of heart attack.   Been working on my Jeep some, now time to go milk.
Well ,that stinks. My sister was telling me her coworker's dad had a healthy apperaing yearling colt just drop dead, found it the next morning, no apparent reason. We've had a lot of goat deaths up our way also, maybe something in the air, one of "those years" type thing.
I have a simliar issue with my Firebird, the body control module has loose solder connections, the radio will go off and windows won't work. It's just been to cold for my to go pull it out and re-solder connections.
hopefully that will fix your issue.
  • olcowhand and oldedeeres have said thanks
#2244 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,053 Thanks
  • 880 posts
Posted January 20, 2014 - 05:53 PM
Glad grandpa is home and feeling much better. Slight chance I might get to see you this weekend. Heading to Texas, I plan on stopping by mom and dads to spend the night Before heading the rest of the way down. Can't bring the twins down cause of sisters in school so it'll just be me and Sue.
#2245 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted January 20, 2014 - 07:10 PM
Well, the computer had perfect solder connections, so I checked fuel pressure & it was great, then headed toward swapping out the ignition coil, but didn't think it was the case as I've had 5 Jeep Cherokee's and none ever had any coil issues.  Soon as I got it unbolted & out where I could get a good look at it, it was apparent the coil was bad.  Cracked all the way up one side, then 2 more cracks starting at the base.  The good  Jeep has flat pin connectors instead of the round pins that the 96 parts Jeep has, so I cut the plugs off, then soldered for a good connection & shrink wrapped them.
Took the Jeep for a drive.................SHE LIVES!   :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:
 Man does that take a load off me!  She ran absolutely perfect.  I spent $108 on the cam position sensor & the crank position sensor which weren't bad, but the coil would have been about $50, so I only overspent about $60, and I saved tons over taking it to a shop.  I pulled the fuel pump when not needed, but I back-flushed the $120 fuel filter which is integrated to the pump, so that was a good thing to do anyway.
 Anyway, here are a couple pics of the coil.
  • IamSherwood, KennyP and oldedeeres have said thanks
#2246 HDWildBill ONLINE
  • 8,975 Thanks
Posted January 20, 2014 - 07:17 PM
Just hold on to the good parts, down the road you may need them.  You still came out ahead!  Glad you got it figured out.
#2247 KennyP ONLINE
  • 37,463 Thanks
  • 45,484 posts
WooHoo! Got something going your way again. Just think of the extra parts as preventative maintenance! Hope it continues to give good service for you!
#2248 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted January 20, 2014 - 07:19 PM
Yes, the extra parts go into the Jeep inventory.  I love having spares anyway, so it's all good now.  I am SO relieved!   :D
  • Craig., KennyP, HDWildBill and 1 other said thanks
#2249 KennyP ONLINE
  • 37,463 Thanks
  • 45,484 posts
Posted January 20, 2014 - 07:21 PM
Well, that's 2 good things today. Dad is back home and the Jeep runs. Gonna try for 3?
  • olcowhand and Craig. have said thanks
#2250 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
I found the short in the electric fence too!  So there's 3!
