* * * * - 22 votes
10621 replies to this topic
#2191 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted January 14, 2014 - 07:01 PM
You got the most important piece fixed, so you can get on GTtalk and relax even if it's only for a few minutes at a time!!
  • olcowhand said thank you
#2192 KennyP ONLINE
  • 38,510 Thanks
  • 45,987 posts
Posted January 14, 2014 - 07:09 PM
Glad something went your way!
#2193 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 14, 2014 - 07:28 PM
Been reading up on my Jeep codes, as I decided to go on out & get the codes.  It would appear I have a MAP sensor issue.  Might be something giving the MAP sensor issues though, so could also be the computer itself.  Further testing should show without taking to a shop.....I hope!
  • Texas Deere and Horse, Craig., sacsr and 2 others have said thanks
#2194 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,930 Thanks
  • 5,976 posts
Posted January 15, 2014 - 08:36 AM
A lot of things can cause a map sensor fault(besides a bad sensor and they do fail).  Bad gaskets, vacuum leaks, wiring issues, and about everything in between, some vehicles the EGR valve can cause problems with it.
Edited by toomanytoys84, January 15, 2014 - 08:37 AM.
#2195 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 15, 2014 - 08:44 AM
Water heater malfunction at milk parlor, so lines weren't cleaned proper.  Just a bad connection, so all is well.  Gonna eat breakfast, then head to Modern Steel, then pick up an ink cartridge for my printer.  I need to print out stuff for taxes, then found ink low.
  Milking went smoothly.   :D
  • Craig., KennyP and oldedeeres have said thanks
#2196 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted January 15, 2014 - 09:19 AM
How do you get away with a straight pipe in this day and age?  When I was a kid (teen) I put a set of straight pipes on my car.  Didn't last long before I was pulled over,  car was impounded, I went to juvenile detention.  I was also skipping school with my girl friend, her mom bailed us out and also got the charges dropped on the condition I put stock pipes back on. :wallbanging: :wallbanging: :wallbanging:
Not true straight pipes, but duals tail pipes with no muffler(s) coming out of the dual cat convertors. It was pretty loud, but I've never gotten pulled over for it. I had the same thing on my 92 S10 /4.3L. It almost sounded like a V8 at low RPM's.
Daniel, hope you find out the Jeep issues without having to spend t much money, those can be a bear to find. Tahoe started missing a few weeks a go, yeah, prefect timing with all the snow, Firebird is just not the ice/snow vehicle if you can believe that :D . Ended up the brand new 100K mile plugs I put in right before plow day fouled out. $48 for plugs and they last less than 4 months :wallbanging:
  • olcowhand, HDWildBill and oldedeeres have said thanks
#2197 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 15, 2014 - 03:06 PM
Got the steel ordered to be bent/cut for the silage mixer wagon.  Ended up saving $200 by waiting to have it done.  Steel price dropped quite a bit.  Should be ready for pickup Friday, so when I go to my heart doc appointment, I'll be pulling a 16' trailer loaded with steel.   2 sheets of 3/8" thick 4'x8' sheets, each $258, plus costs for shearing one sheet to 4', and 6 bends on 2 sections.
  Also dropped papers at the tax office, got ink for my printer, ate lunch, got a new well pressure/bladder tank & fittings to fix a couple small leaks in the parlor, got 2 small bottles of propane so I can flame clip the cow's udders, visited Dad at rehab, then home.  Busy day!   Just gonna feed silage and then do some bill paying.
  • Texas Deere and Horse, Craig., KennyP and 2 others have said thanks
#2198 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,930 Thanks
  • 5,976 posts
Posted January 15, 2014 - 03:18 PM
You didn't do too bad on the steel.  The last sheets I ordered for work were 227.50 a sheet.  That was on 11/13/2013.  I don't know what her current price is.
  • oldedeeres said thank you
#2199 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Not sure what that means other then you are removing hair from udders with flame?
#2200 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 15, 2014 - 03:24 PM
Yep, a lazy flame, not like a torch.  Just wave it under the udder, and it fries the fuzzy straggly hair that attracts dirt/sawdust & the like.  Makes the cows SO much cleaner, and helps keep mastitis down too.  Nasty/stinky job burning the hair off though!
#2201 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 15, 2014 - 03:25 PM
Same size/thickness as I got?
#2202 UncleWillie ONLINE
  • 15,679 Thanks
  • 8,766 posts
Posted January 15, 2014 - 07:35 PM
As long as you are paying bills, you want some of mine?
Glad to hear things went fairly well today.
  • KennyP and oldedeeres have said thanks
#2203 Craig. ONLINE
Craig.
    Ronald Craig
  • 1,097 Thanks
  • 903 posts
Posted January 15, 2014 - 08:04 PM
I'm making it as fast and as cheep as I can! LOL
#2204 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 16, 2014 - 08:48 AM
BUSY today.  Once I eat breakfast, it's back to the parlor for flame clipping udders.  Then after lunch, I MUST patch the silage wagon, as a hole 8" across fell out of it this morning.  Stalls need to have new chips spread also, but Josh will have to start it, and may have to finish, depending on how long the wagon repair takes.
  • Craig. and oldedeeres have said thanks
#2205 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 16, 2014 - 08:58 AM
Flame clipping udders??????
If it's like the picture I have in my mind, I can't watch. Shuuuddddddeeerrrrrr.
