Newbie Need Help
17 replies to this topic
#16 English OFFLINE
English
  • 19 Thanks
  • 62 posts
Posted April 12, 2012 - 07:43 PM
George those cows are tuned in to any motor they hear running. If it's not a car they just assume whatever is running is coming to feed them! Actually quite often I rake up some of the clipings and toss them over the fence for the cows so the lawn mower is a double whammy on them!
I figured out the starter has the wrong gear on it. Trying to find the correct one now. Or a way to rebuild the original.
#17 MH81 OFFLINE
Posted April 12, 2012 - 08:07 PM
Often, the bendix alignment is the major issue. If you're able to loosen both mount bolts and twiddle with it some, you can get them to behave. I had to put thin spacers under one of them to get the desired effect.
I see you said it's the wrong gear, is the tooth count off?
Also, if you're looking to rebuild the original... is the bendix assembly the same on them & is the original gear OK? if so, just swap parts around until you get what you need.
#18 English OFFLINE
English
  • 19 Thanks
  • 62 posts
Posted April 12, 2012 - 09:37 PM
Yes the tooth count is off. The original has 10 teeth while the replacement has 11. I've been emailing a local guy this evening. I'm going to see him tomorrow afternoon and see if he has something that will work or if he can rebuilt the original. The starters I have do not have interchangable parts....at least not the ones that need changing! LOL
