3 Point Lift Cylinder For Mf14, 16
67 replies to this topic
#16 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 06, 2012 - 08:24 PM
I messed with it a bit today, basically tried to mount the 3pt to the tractor directly and I think it"ll work.
Need to find the right spot to mount the rock shaft mounting brackets so it works right and clears the rear fender seat pan.
Also need to get a cylinder and a diverter valve or a 2 spool control valve.
#17 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted April 06, 2012 - 08:46 PM
I'm with tudor, as I think it's about the same stroke as the belly lift cylinder, around 4 to 4 1/2". My memory escapes me on exact figures. I never had a factory MF14 3pt lift, but I did have one of the cylinders at one time for one.
#18 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 06, 2012 - 09:52 PM
I just checked the AGCO parts books and for the MF16 tractor the hyd cylinders have the same body, piston, seals rod are the same, they have the same part #s.
That means that the diam and stroke will be the same for both mower and 3pt lift.
For the MF14 tractors made serial # 6559 and up (1/2 way through 75) use the same cylinders as the 16. Before that different ones were used.
Learn something new everyday.
#19 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 08, 2012 - 07:24 PM
I read in another thread that the ends of the arms should have 16" of travel, and be.
4" off the ground in the lowest position
20" off the ground in the highest position
Does this sound about right?
#20 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 08, 2012 - 07:34 PM
Doug, you could do it like I did on my MF16. That's a 1450 3pt. The lower arms are attached to the axle, but
in order to maintain the geometry, I made up a standoff bracket.
  • safetyfactorman said thank you
#21 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 08, 2012 - 07:37 PM
Maybe a bit smal to read. Bigger files are in the manuals somewhere. In MF I think.
Edited by IamSherwood, April 08, 2012 - 07:39 PM.
  • DH1 said thank you
#22 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
That's the set up I'm going to try to make it is a close match to the original.
#23 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 08, 2012 - 07:45 PM
Well, you've got the dimensions on that pretty grey tool box.
Notice how I had to mod the cylinder mount on the rockshaft.
#24 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 08, 2012 - 07:55 PM
Yes I did and that's the key to modify the rockshaft so the fender pan fits without cutting it up.
#25 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 09, 2012 - 08:26 PM
So I guess this is what I need to get here > http://www.princessa...tility-Cylinder
#26 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted April 09, 2012 - 10:58 PM
Does anyone know how this electric version might work in this situation?
http://www.northernt...33211_200333211
Thanks
#27 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted April 09, 2012 - 11:46 PM
Thanks
Compared to DH1's cylinder, slow and not very strong.
Speed: 8 mm (5/16")/sec ======= 1.75"/sec @ 2 gpm (Charge Pump)
Max Thrust: 1350 lb ======= 2200 lb @ 700 psi (Charge Pump)
Rated Load Thrust: 375 lb ======= 9420 lb @3000psi.
The reasoning for the screwy numbers for the 2 thrust ratings for the cylinder; 2200 lb is the thrust that can be generated by the pump and 9420 lb is what it can handle as an impact load going over a big bump at speed. The electric unit can develop 1350 lb, but it can only hold 375 lb..
  • HowardsMF155 said thank you
#28 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted April 10, 2012 - 08:48 AM
Thanks Bob
#29 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 10, 2012 - 01:29 PM
Doug, on that setup I did, the bottom of the cylinder is 8 1/2" off the ground. The cylinder
is 10" pin center to center when retracted. That Princess cylinder isn't going to leave you
much ground clearance, unless you can figure out some fancy bracketry for the rod end
mount.
#30 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted April 10, 2012 - 02:01 PM
mount.
Possible solutions; lay the cylinder down under the seat a la 1450-1855 tractors, or, along the outside of the frame and behind the tire as I did with my 12H (if clearance allows). I used a 1.5 X 8 cylinder on the 12, with a longer bellcrank for the rockshaft.
