Reference sheet for small engines
6 replies to this topic
#1 fordmustang1984 OFFLINE
fordmustang1984
  • 23 Thanks
  • 428 posts
Posted June 17, 2010 - 12:10 PM
Is there a reference sheet for identifying small engines that covers all the major makers? (Kholer, Onan, Tecumseh, Briggs and Stratton, Wisconsin etc.) One that goies through the basic model numbers and HP ratings. ie. HH120=cast iron block 12hp, OH120=cast iron block overhead valve 12hp, and so on for the manufacterers above.
#2 Bolens 1000 ONLINE
  • 12,923 Thanks
  • 17,296 posts
Posted June 17, 2010 - 05:39 PM
I have the Tecumseh master mechanic's manual and Master parts list from 1978 if that will help at all.........
#3 fordmustang1984 OFFLINE
fordmustang1984
  • 23 Thanks
  • 428 posts
Posted June 17, 2010 - 08:10 PM
It might, since if no booklet exists, then I will attempt to make one.
#4 Bolens 1000 ONLINE
  • 12,923 Thanks
  • 17,296 posts
Posted June 17, 2010 - 08:20 PM
That's going to take quite a bit of work and time......
but that would be helpful to have one
#5 fordmustang1984 OFFLINE
fordmustang1984
  • 23 Thanks
  • 428 posts
Posted October 26, 2010 - 05:46 PM
i'm (finally) coming back to this after some searching, and found that no book appears to exist. So i think we, the members of Gttalk should make one. Any takers?
#6 jdslednut OFFLINE
jdslednut
  • 644 Thanks
  • 838 posts
Posted October 26, 2010 - 06:12 PM
I have access to about any Briggs information you would want if that helps and could probably dig up a bunch of the rest. Time is the issue here.
#7 NUTNDUN OFFLINE
  • 10,269 Thanks
Posted October 26, 2010 - 07:54 PM
It would take time, as long as you have the drive to do it.
