Spring Break Project
#61
ONLINE
Posted May 02, 2012 - 07:47 PM
I am only using stuff I have on hand, like Steve said. I have so much of that square stock its not funny. My dad used that stuff to make tire racks for his tire buissness and now we have all the racks left over.
Thanks for giving you opinions on the tongue strength. I always clamp everything together as tight as possible before welding, this will be no different.
#62
ONLINE
Posted May 03, 2012 - 08:43 PM
What exactly does the diameter of the welding wire do? I am using 0.030
Goals for tomorrow:
1) Weld main frame together
2) Weld tongue together
#63
OFFLINE
Posted May 03, 2012 - 08:51 PM
#64
ONLINE
Posted May 03, 2012 - 08:53 PM
The size of the wire determines the current capacity. Smaller wire will make cleaner more penetrating welds in thinner materials without blowing through (assuming the settings are proper). The .030 wire should be OK for what you're doing. Are you using flux core or solid wire / shielding gas?
Im using solid wire and gas.
#65
OFFLINE
Posted May 04, 2012 - 04:55 AM
#66
ONLINE
Posted May 04, 2012 - 07:34 AM
#67
ONLINE
Posted May 04, 2012 - 05:14 PM
Here is a main frame.
I set the tongue and frame together so you could see what it will look like.
I was surprised at how fast I was able to weld this together, it took me just under 2 hours to do. Talking about welds, I thought I would take a pic of one of mine from that I did on the main frame. I dont think it's a bad weld, especially considering the amount of experience I have. This is one of the more "average" welds on from this project, some are better and some are worse. Also, this will probably be the only time I brag about something. Lol.
I will go out in another hour or so and see if I cant get the tongue and main frame welded together.
#68
OFFLINE
Posted May 04, 2012 - 05:31 PM
- Ryan313 said thank you
#69
ONLINE
Posted May 04, 2012 - 06:25 PM
Ryan, it's looking good. Looks like a good weld. I wish I could weld.
Thanks Dave! All you need is a welder to learn! I'm self-tought and I only started last fall.
#70
OFFLINE
Posted May 04, 2012 - 06:30 PM
#71
ONLINE
Posted May 04, 2012 - 09:22 PM
Goals for tomorrow:
1) make a jackstand
2) mount battery
#72
OFFLINE
Posted May 05, 2012 - 10:33 AM
#73
ONLINE
Posted May 05, 2012 - 02:40 PM
Here is the bottom of it.
I put the compressor onto the trailer, next. After I put it on I lifted the front to see how heavy it was and it really was not bad at all, I was able to wheel it around without a problem.
I then started making the jack-stand. The first thing I did was make a foot for it. To do this I used a wheel I had laying around. This is one of the wheels that unbolt into two halves. On the side without the greese zirc or valve stem hole I wrapped some blue tape around it.
I cut the wheel, using the blue tape as a guide. The part with the center still in it was used as the foot.
I put a piece of threaded 3/4 rod into the foot and on one side I locked two nuts together.
The other side has a washer welded onto it.
I then put two nuts onto the rod and welded a piece of flat stock to it.
I welded the piece of flat stock to the tongue of the trailer.
The last part to make was the crank, I simply welded a piece of 1/2 round bar to a piece of flat stock and then welded a nut to the other end.
I put the crank onto the end of the threaded rod and locked it on with another nut.
Here is the finished product! It works perfect! The only downside is that you have to crank it a lot to move it very far.
#74
OFFLINE
Posted May 05, 2012 - 02:48 PM
#75
OFFLINE
Posted May 05, 2012 - 03:25 PM
That is awesome, Ryan. Love that jack stand. That's using the brain matter.
I agree with Kenny. VERY well done Ryan. Congratulations. That is a first rate job.
