F100 Rear Rims?
6 replies to this topic
#1 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted March 29, 2012 - 07:54 AM
anyone swap out the factory rims for any reason? just curious if the bolt pattern matches up with any automotive rims?
#2 mjodrey OFFLINE
Posted March 29, 2012 - 08:06 AM
5 on 4.5" bolt circle is the same as the Ford Ranger,some F100's, but not all. A lot of Ford cars in the '60s,'70s,and '80s had this pattern too.Of course rim diameter,and offset might be a factor to consider.
Edited by mjodrey, March 29, 2012 - 08:07 AM.
#3 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted March 30, 2012 - 06:38 AM
thanks, i thought thats what they were but the wheel weights were in the way to be sure.... literally hundreds of different cars and styles of rim to choose from :-) im considering modifying the front spindles to a 1" trailer spindle, allowing use of larger tires as well for more clearance and durability. so i think a set of nice 14's will go good on the back..
#4 KennyP ONLINE
  • 40,161 Thanks
  • 46,776 posts
Posted March 30, 2012 - 06:46 AM
Another factor to consider is the center hole. They have to clear that as well!
#5 mjodrey OFFLINE
Posted March 30, 2012 - 06:58 AM
Good point,I forgot to mention that.
#6 KennyP ONLINE
  • 40,161 Thanks
  • 46,776 posts
Posted March 30, 2012 - 07:57 AM
A lot of Mopar wheels are same bolt circle, but a different center hole. I can't remember which had the larger hole, I think Mopar. But that was a few years back!
#7 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted March 30, 2012 - 04:03 PM
i already thought about that.... but thats what torches and grinders are for
