Bolens 18704-01 Front Pto.
15 replies to this topic
#1 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 26, 2012 - 06:38 PM
Hello! Just acquired a bolens front mounted PTO. I plan on trying to run a generator on this PTO. I was wondering if any one knows what attachment were run on this front mounted PTO. Thanks again Steve,,,,
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 26, 2012 - 10:00 PM
The 18704 converts the Bolens 2000 RPM PTO to the "standard" agricultural 540 RPM PTO.
It would be used to run things that didn't require a lot of power like hay elevators, grain augers, etc.
There ware a couple of different front PTO units.
One was just a direct drive with a pulley, another gave 540 RPM that was turned 90 deg to the tractor, and there was one made by RoWay that went straight out the front.
Here's a brochure on the RoWay that shows it being used with a hay elevator:
Edited by OldBuzzard, March 26, 2012 - 10:01 PM.
  • sieborg400 said thank you
#3 Bolens 1000 ONLINE
  • 17318 Thanks
  • 18800 posts
Posted March 27, 2012 - 04:36 AM
The Bolens PTO speed is not 2000 RPM. The ratio on the tubeframes was 1:1 for a max of 3600 RPM.
The 18704 PTO kit was also 3600 RPM, but could be lowered depending on engine speed.
Different size pulleys were also available which would lower the RPMS.
  • Bruce Dorsi and sieborg400 have said thanks
#4 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 27, 2012 - 06:39 AM
Looks like I read my Attachment Guide wrong. It appears that the 18905 was the 540.
I though that that the PTO pulleys were different sizes which reduced the 3600 engine speed down to 2000 PTO output.
sieborg400, how about a pic or two so we know what we are talking about?
Edited by OldBuzzard, March 27, 2012 - 06:42 AM.
#5 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 07:12 AM
Thanks guys! I will try to add a pic!
Edited by sieborg400, March 27, 2012 - 07:16 AM.
#6 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 09:54 AM
Here it is and it has a bolens tag!
bolens PTO
#7 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 06:25 PM
Thanks again! Bolens 1000 you said the pto speed on my tube frame is 3600 rpm. I can run a direct drive to a generator head of about 4000 watts with a 10 hp engine. I was hoping some day to I would come accross a generac gen built for a bolens but I think I can build one using this set up! if some one has pics of the original generator for the tube frame that would really help me. Thanks Steve...
#8 Bolens 1000 ONLINE
  • 17318 Thanks
  • 18800 posts
Posted March 27, 2012 - 07:14 PM
Yes, the speed of the PTO is rated at 3600RPM at full throttle.
I have the same PTO attachment you posted a picture of. Where did you get yours from?
#9 Bolens 1000 ONLINE
  • 17318 Thanks
  • 18800 posts
Posted March 27, 2012 - 07:15 PM
Tubeframes were 1:1 (3600RPM) The large frames were (2000RPM)
#10 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 07:46 PM
I found it on ebay! I paid the price! But I think i can use it to power a generator? I really need to see a pic of the original gen set that was used on the tube frame. We loose power twice a year around here. Thank for any info you have!!!!!
#11 Bolens 1000 ONLINE
  • 17318 Thanks
  • 18800 posts
Posted March 27, 2012 - 07:56 PM
Did you win this recently?
I usually check ebay daily and dont recall seeing this on there.
You can power basically anything you want with this attachment, so I am sure you could fabricate something that would hold a generator on the front.
Are you planning on having the Generator be stationary on the ground and move the tractor up to it or are you looking on mounting it directly to the tractor where you can drive with it?
Here's an old thread posted by one of our members: http://gardentractor...h__1#entry48665
#12 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 08:12 PM
Yes Buy it now!The original generac is a direct drive! I will use simple angle iron and a new brushless gen set head. Go on line PTO generator belt driven! attach a bolens drive shaft and it's running! It will be a challege but I think I can do It!!!!
#13 Bolens 1000 ONLINE
  • 17318 Thanks
  • 18800 posts
Posted March 27, 2012 - 08:14 PM
Sounds like a fun project
Please post pictures when you get started :D
#14 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 08:22 PM
Time and money!!! I will try but you know prioritys get in the way!!!!
Edited by sieborg400, March 27, 2012 - 08:23 PM.
#15 sieborg400 OFFLINE
sieborg400
  • 22 Thanks
  • 82 posts
Posted March 27, 2012 - 08:54 PM
This is a pic that I want to build!!!
bolens generac alternator
