Started Working On My 317 Restoration..
317 drivshaft power steering conversion
13 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted March 25, 2012 - 10:16 PM
Last weekend I posted that one of my 317's that I was tilling with had a drive shaft failing. Yesterday after work, I puller the other 317 to the shop because the starter was out and I knew it had a good drive shaft in it to repair the other 317 and get back to tilling the garden. After I pulled the engine and the seat pan, I decided it was time to go ahead and strip it down to the frame and do a full restoration. Last night I got the drive shaft installed in the running 317 so I could get the garden tilled again. This morning I had to finish my neighbor's deck for his Kubota 1600HST Diesel, if you remember I posted a while ago that I picked up the same model Kubota complete with a good deck. I sold my neighbor the deck for what I had in the whole thing and got a great diesel for my JD 140 H-3 diesel project. Sorry, back to the story. After I got his deck done and tilled the garden, I finished striping the 317 down to the frame. I am going to set up my electrolicis tank in the couple days to do all the sheet metal. The seat pan has a lot of surface rust, but not much pitting. I'm going to pressure wash the drive train and hit those parts that I don't remove with wire wheel. here is a few photo's of what I have got down to so far.
2012-03-25_19-19-38_594.jpg 2012-03-25_19-19-28_620.jpg 2012-03-25_19-19-44_878.jpg
To be continued......
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 26, 2012 - 04:17 AM
Brian, I did my 314 last summer. I spent many, many hours on the fender deck. If you can get it in the E tank that would save you a lot of work. I removed the decals on mine with a heat gun and a scraper. The PO had painted over top of some of the decals. It had 2 coats of primer, one that had been brushed on and then a bad spray job. I am thinking of picking up one of those big square tanks to use for large stuff like this as it is so much easier to use electrolysis. I like the styling of these fender decks better than the squared off 318 version. Also, the tail lights can be easily and cheaply replaced with LED versions. Thanks for the pics and please keep posting progress on this restoration.
#3 mjodrey OFFLINE
Posted March 26, 2012 - 04:26 AM
Brian (T D AND H),you have a good start to your project.Can't wait to see more photos.
#4 grnspot110 OFFLINE
grnspot110
  • 4,268 Thanks
  • 2,677 posts
Posted March 26, 2012 - 06:30 AM
Looks like you're off to a good start! :thumbs:
Keep us posted on your progress! ~~ Lowell
#5 KennyP ONLINE
  • 40,004 Thanks
  • 46,714 posts
Posted March 26, 2012 - 06:57 AM
Good to hear you got the other 317 fixed with parts from this one. Looks like you are going to be occupied with this for a bit. A large e-tank would be nice for that fender pan. Thanks for the before pics.
#6 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 26, 2012 - 07:05 AM
Looks like you got a good jump start on it. The E-tank should do a good job on that tin.
Looking forward to updates.
#7 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted March 26, 2012 - 10:19 AM
Here is a couple pictures of the tank I'm going to use. It is 41" tall, 37" wide, 45" long, and has a 3" drain valve at the bottom. A friend of mine had 3 of them and gave me one to use.
2012-03-26_09-53-37_941.jpg 2012-03-26_09-53-54_3.jpg 2012-03-26_09-54-38_861.jpg
I think the seat pan will fit in it all at one time, :laughingteeth: if I watch what I'm doing and don't let it touch in the bottom. :wallbanging:
#8 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted March 26, 2012 - 10:35 AM
hope you have a big battery charger.
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 26, 2012 - 02:46 PM
I've seen those tanks here for 100 -150$ so your friend gave you a nice gift. That's the same type I was looking at. That will save you hours if you can get the whole seat/fender pan in there.
#10 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted March 26, 2012 - 02:59 PM
I have a 250 Amp roll around truck charger that should do the job, I hope??
I do a lot for him and he does for me, It's the same guy I rebuild the Kubota deck for. We also share the garden spot between our homes..
#11 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted March 26, 2012 - 03:19 PM
Should get it done. I made a 100 gal E-tank and my 20 amp charger had a hard time with it.
#12 daytime dave OFFLINE
  • 4,935 Thanks
  • 6,579 posts
Posted March 26, 2012 - 03:24 PM
Looking good Brian. It's nice to have good neighbors too. You do for them one day and they do for you another. Good luck with the tank.
#13 KennyP ONLINE
  • 40,004 Thanks
  • 46,714 posts
Posted March 27, 2012 - 04:20 AM
That should make a nice tank, Brian. Good luck with it!
#14 mjodrey OFFLINE
Posted March 27, 2012 - 04:52 AM
Yep,that will make a nice tank.
Also tagged with one or more of these keywords: 317, drivshaft, power steering conversion
