Mower Deck Rebuild
bolens mower deck 18420
51 replies to this topic
#46 mark843 OFFLINE
mark843
  • 141 Thanks
  • 252 posts
Posted May 20, 2012 - 06:29 PM
I got the mower deck done. It does not seem to be leaking oil now but I will watch it the next few days. Here are some pics of it. How hard should it be to slide the u-joint onto the horizontal shaft? Mine is too tight to push on and I needed to use my rubber mallet.
Here is some pics of the lift linkage. Is this the way they go on?
Also, what is the easiest way to get the mower deck under the tractor?
Edited by mark843, May 20, 2012 - 06:32 PM.
#47 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted May 20, 2012 - 07:39 PM
Having to tap on the universal onto the gear box shaft is normal. On all the ones I have done they all required a bit of persuasion with a mallet to get them back on.
To get the deck under the tractor I usually pick up the one rear tire and slide a small block of wood under the wheel so the gearbox clears the deck lift brackets.
  • mark843 said thank you
#48 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted May 20, 2012 - 07:43 PM
.........Hope these pics Help you with the deck brackets, these are the only ones I had saved to my computer with this mounting system
#49 mark843 OFFLINE
mark843
  • 141 Thanks
  • 252 posts
Posted May 21, 2012 - 08:01 AM
Thanks for the pics! It looks like I have them on correctly. I hope to finish up my 1050 this weekend and get some seat time. :dancingbanana: When I was moving the deck around, the wheels seemed a little wobbly. I assume this should not happen? I will take a look to see if they need to be tightened or if they are just worn. It will not stop me from using the deck though as I should be able to work on them even with the deck mounted.
Edited by mark843, May 23, 2012 - 09:07 AM.
#50 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted May 21, 2012 - 08:14 AM
Its hard to tell from the pics, but it looks like you have the older style wheels with metal rims??
The ones I have on the red deck are the "Newer" style" that were all plastic. It is very common for these wheels to have some slop in them as they are 30-40 years old.
#51 mark843 OFFLINE
mark843
  • 141 Thanks
  • 252 posts
Posted May 23, 2012 - 09:06 AM
Yes they look to be old style. Here is a pic.
I hope to get it the mower deck mounted and use it this weekend. I have been reading a little about how to mow, so I guess the correct was is to have the throttle open all the way and go a medium to medium fast gear but not the fastest?
I don't see any oil leaking but the real test will be when I use it for an hour or so to mow the lawn.
#52 Bolens 1000 ONLINE
  • 17541 Thanks
  • 18861 posts
Posted May 23, 2012 - 06:51 PM
Yes, those are the older style heavy duty wheels.
I think I'd just leave those on as there is not much to wear out compared to the plastic ones.
