The pulleys are the same width, it's just the bigger looking one is closer to the camera. I don't think I need washers so much as the correct way all the parts go together, but if I do, I have some washers.
I think the previous owner assembled it wrong as #34 seemed to be on the wrong sides of the idler arms when I took everything apart. It did not look like the picture. The special bolt, #37, was also upside down from the parts diagram and it looks like it bent the top plate a little because of it.
I was referencing
this thread for the way the belt loops around and see #37 looks to go on after the top plate, is this correct? The diagram looks to be different.
Does the wider shoulder on the pulley face up or down? In the diagram it looks to be up, but then the spacer (#11) would have to be on the bottom of the other pulley if the shoulders face up, so I assumed the shoulders go down?
Here is a picture of the parts minus the pulley and the arms.
Does #34 look to be the correct orientation or do they need to be flipped?
Does this look to be correct on the way everything sits on the bolt?
I apologize for all the questions but this seems to be perplexing me and I want to make sure it is correct so I don't have an problems.
Edited by mark843, May 06, 2012 - 03:59 PM.
