Propane Powered Garden Tractor
10 replies to this topic
#1 philips100 OFFLINE
philips100
  • 72 Thanks
  • 82 posts
Posted March 24, 2012 - 10:33 PM
Has anybody ever converted a tractor to run on propane? I have been thinking about doing a propane conversion and wondered how others did their conversions.
#2 CASENUT OFFLINE
  • 505 Thanks
Posted March 24, 2012 - 11:50 PM
IDK but I'd be interested in this too...
#3 mjodrey OFFLINE
Posted March 25, 2012 - 04:33 AM
I don't know about GT's ,but it was done on big tractors back years ago.
#4 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted March 25, 2012 - 06:12 AM
Maybe you could adapt a set-up from a RV propane generator .Do you think it would be cheaper then gas ? Al
#5 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted March 25, 2012 - 09:03 AM
I have no knowledge on this, but this is the only thing I could find related to GTs.
EDIT: forgot the link
http://forum.thesmal...p?topic=18586.0
Edited by Ryan313, March 25, 2012 - 09:04 AM.
  • philips100 said thank you
#6 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted March 25, 2012 - 09:32 AM
I once rebuilt a Kohler K 321 for a guy. It was used on a power sweeper in their plant and ran off propane. I didn't get to see how they rigged it up on propane, but it used the stock Carb., maybe only as a air metering valve?? It was very clean inside the engine because propane has no carbon residue like gasoline does.
#7 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted March 25, 2012 - 10:36 AM
Most any engine can be run on propane. There are carburetors made for this and they can also be multi-fuel {Gasoline -propane}.
Straight propane engines can be run at a higher compression ratio because it has a high octane rating.
#8 philips100 OFFLINE
philips100
  • 72 Thanks
  • 82 posts
Posted March 25, 2012 - 07:31 PM
I found this site:
http://www.propanecarbs.com/
It has information on different types of propane conversions, one modifies the existing carburetor, another uses an adapter plate with the original carb and the last uses a dedicated propane carb.
Al, the cost of propane varies quite abit, at least in TN. The cylinder exchange racks are too expensive. Refueling your tank at the local utility or hardware store costs about the same as gasoline. There is one boat and RV center here that is selling propane at a $1.99/gal.
I can understand the benefits of using propane on small engines. Especially ones that are not used for long periods of time.
I wonder if running a small engine without hardened valve seats on propane would cause premature wear on the seats more quickly than running the same engine on the gasohol we have now.
#9 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted March 25, 2012 - 08:11 PM
Well, I have a JD 318 with cck style cast block 24 hp propane engine, old 18 was blown, so repowered. So many projects so little time. It has been in storage for about two years,not finished............... tossing around converting it to CNG and putting on my Allis 620. It is a true propane engine, no float in carb. need any more info , PM me, Shawn
#10 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted April 04, 2012 - 09:52 AM
Posted Imagewhat kind of motor u putting it on this carb is for a kolher engine
#11 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted April 04, 2012 - 09:54 AM
Posted Imagehere are some more photos ebay has this one for sale at 169.99 new Posted Image
