Desperately Seeking Carburetor
9 replies to this topic
#1 rkman OFFLINE
rkman
  • 3 posts
Posted March 24, 2012 - 07:07 PM
My 1975 MTD 990 is in desparate need of a carburetor. My engine number is 326431-0139-01. build date is late in 1974. I have tried all my local shops here in Nova Scotia but to no avail. I do want to spend the money on a new one (yet) becasue I have not had the tractor running enough to make sure there are no other major issues. Can anyone help me. Thank in advance
#2 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 24, 2012 - 07:11 PM
2 peice flow jet, up-draft.
Call (4one3) 3six9-800six, ask for Kevin, give him the model no.
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 24, 2012 - 07:57 PM
Is your carb beyond rebuilding? What is the issue you are having with this carb? There are a couple issues with these carbs but If you take your time rebuilding you can fix it yourself. biggest problem is when you put it back together the top half has a tendency to be warped, (it's a bad design) and if you don't fix it will leak gas bad, the other issue is the metering tube that the high speed needle sits against tends to not seat well and causes fuel to come out the bottom of the carb ( acts like a stuck float) if you have any of these symptoms then you can repair the carb, rebuild kits are cheap for these. Let us know what type of problem you are having.Maybe we can help walk you through. Good luck.
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 24, 2012 - 08:01 PM
I just noticed you replaced the mixture screws, did you rebuild it already?
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 24, 2012 - 08:08 PM
Sorry i thought you said broken, that will teach me to read slower and more carefully, explain what the carb is doing (problems), what you have done to it (rebuild?), is this a new problem or has slowly become a problem ?
We can help, it's not hard to find parts for thoses and we have used ones kicking around.
P.M. Chris, thanks, im half awake.
#6 mjodrey OFFLINE
Posted March 25, 2012 - 04:28 AM
rkman,welcome to the forum.Glaad to have you with us.
Where in Nova Scotia here are you located ?
Edited by mjodrey, March 25, 2012 - 04:29 AM.
#7 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted March 25, 2012 - 08:47 AM
I hope you it fixed, I have the Carb on mine with no issues, but in the future I'm sure I will. These guys will get you through this. :thumbs:
  • trowel said thank you
#8 rkman OFFLINE
rkman
  • 3 posts
Posted March 26, 2012 - 08:09 AM
I am located in Chester Basin on the South Shore of Nova Scotia................ and unfortuneatly the bottom bowl is stripped out (at needle valve), and either the upper or lower piece is warpped enough that I have at least a 1/16th of an inch gap. Along with that the throttle is very worn and loose. I was told not worth trying to rebuild, but try and locate another one. The bad part is, when I purchased my MTD990, the carb was shot and before I put out for a brand new carb ($$$$) I was hoping to track one down to make sure all was well with the tractor. Thanks Richard
#9 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 26, 2012 - 08:13 PM
And then call this number, i think he still has one that works, very helpfull or i would not send you to him,
#10 rkman OFFLINE
rkman
  • 3 posts
Posted March 27, 2012 - 01:39 PM
Thanks, I will give him a call when I get a chance.......... appreciate the information
