Trailer Wheel Wing Build
66 replies to this topic
#1 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 24, 2012 - 06:04 PM
First off, I dont know what these are called but, wheel wings sounded catchy. When I built this trailer this summer I noticed quickly that the tires would be catching things in turns. Using it in the woods most of the time for fire wood the trees can be a problem. I have been wanting to make something to put an end to this problem.
This is what i came up with.
I got 95% of the pieces cut. I welded one side together but I need to cap off the one end before I weld it on the trailer. Being that this is pretty thin stock I put another piece in the middle to keep it from folding on itself.
I have to grind and weld the other side together then cap both of them off then weld them on.
More info on the trailer below.
http://gardentractor...-trailer-build/
Thanks for looking!
#2 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted March 24, 2012 - 06:24 PM
I think you need to see some old stock cars ,they had the same things , we used to call them " rub rails " :smile1: Al
  • Ryan313 said thank you
#3 KennyP ONLINE
  • 40,889 Thanks
  • 47,094 posts
Posted March 24, 2012 - 06:30 PM
That ought to help get it to 'zero turn' around the trees! Yep, rub rails is what they be! Good job and ingenuity, Ryan.
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted March 24, 2012 - 06:34 PM
We called them "Nerf Bars".
  • Ryan313, frankreno and RoosterLew have said thanks
#5 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 24, 2012 - 07:24 PM
Thanks guys! I figured that people would have different names for them. Rub rail sounds firmiliar.
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 24, 2012 - 07:56 PM
Nice build on those "tree kicker bars".
Hey, everyone else was making up names too lol.
#7 Michiganmobileman OFFLINE
Posted March 24, 2012 - 08:27 PM
Good solution to your problem Ryan. Are you going to put a set behind the tires too?
#8 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 24, 2012 - 09:01 PM
I thought about putting a set behind the tires but I don't think I need them and I don't see them doing much there anyway. Maybe I will just put a straight piece behind the tires.
#9 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted March 24, 2012 - 11:44 PM
Well done Ryan,those will serve you well. Way to use your head.. :thumbs:
#10 mjodrey OFFLINE
Posted March 25, 2012 - 04:26 AM
That's a great idea Ryan.
#11 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 25, 2012 - 01:18 PM
Thanks again for the kind words! I welded the other side together and capped them off. The second side went much faster then the first.
I will weld them to the trailer hopefully tomorrow.
#12 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted March 25, 2012 - 02:48 PM
Looking good! Those should get you around those trees nice and easy now.
Geno
#13 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 25, 2012 - 04:57 PM
Can't wait for the video lol.
#14 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 25, 2012 - 05:16 PM
Thanks Casey! I guess I have no choice now! lol. After im done I will take a video of it being pulled around the woods.
#15 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 25, 2012 - 07:15 PM
Thanks Ryan. Wise person once said if you build it they will come. In this case if you post it they will have to do it lol.
