Ford 195
10 replies to this topic
#1 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted March 24, 2012 - 08:55 AM
Hey all,, I have a FORD 195 Tractor an it's between 1977 to 1980 from what I have found out on this Forum I was here a while back but had prob's with computer an lost everything,, Well I trying to pick up where I left off at,, So,,,, I need to put a new Key Switch on my 195 an can't fig things out on the switch,,, My old switch has letters on it an are B,R,I,S,A, an my new switch letters are B,G,M,S,L, I do have the wireing diagram for my tractor,, But with the new switch I can't fig out what wire goes where, My Motor is the 20hp Kohler Twin cylinder engine,,,, Tractor has the P.T.O. I am going to restore my 195 but want to get the key switch fix first, I start it with a push button switch right now an want to take it off,, I sure hope somebody can help me with telling me where which wire I should put where,,, Thanks an hope to hear from ya'll,,,, An Sure feels good to be back in here,,, Thanks again Picture 012.jpg
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 24, 2012 - 09:15 AM
Russ those are 2 different switches.
B,R,I,S,A, this one is for a point ignition system w/ a coil B-battery, R-regulator I-ignition - S-starter, A-accessory,
B,G,M,S,L this one is for a solid state or magneto ignition system.
B-battery, G-ground, M-magneto, S-starter, l-lights,
Hope this helps.
#3 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 24, 2012 - 09:16 AM
If the ignition system on your engine uses a battery powered coil, then your new switch is wrong. If it uses a magneto ignition, then you have the correct switch.
If your engine has magneto, the new switch goes like this:
B= battery
G= ground
M= magneto kill wire
S= starter solenoid
L= lights
Glad you found your way back to GTT!
#4 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Ducky beat me to it!
#5 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted March 24, 2012 - 09:47 AM
Thanks guys for ya help,, I do have the points ignition system on my motor,, So that means I need to find another key switch with the same letters on it as the old key switch ??
#6 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 25, 2012 - 07:37 AM
Yes, you do need the same letters. These should be pretty common at NAPA and such. Just take the old one with you to match up.
#7 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted March 25, 2012 - 08:30 AM
Yea now I see that there is a diff in the switchest an will be getting one monday that will have the same letters as mine is,,, Thanks guys
#8 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted March 26, 2012 - 06:41 PM
Well guys this post is done now cause I fix my key switch with a new one,, An come to find out that as I been going thru the wires an seen where somebody had the wrong wire cross over on the silaiod,,, Thaks for all the help on here but will be around cause I going to be haven updates of pic an talks about my 195 an hope ya'll will still joing me even if ya don't have a 195 or a FORD,, An if anybody need to ask anything about the 195 then ask away cause I be learning alot I hope an with the help from this Forum Thanks again ya'll :bounce:
#9 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 26, 2012 - 06:49 PM
Russ, I hope we hear a lot more out of you. Good luck with that monster tractor!
  • Russ said thank you
#10 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted March 26, 2012 - 08:30 PM
You sure will,, Even after I get my 195 all done I will still be here,,,
#11 mjodrey OFFLINE
Posted March 27, 2012 - 05:50 AM
Russ,that's a pretty good looking 195 you have.
