Wheelhorse 105 Stuck In High
2 replies to this topic
#1 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted March 20, 2012 - 04:48 PM
A buddy of mine bought a C105 with a tiller and it is stuck in high range have not looked at a parts diagram yet.He is supposed to give me the model number and serial number later on the phone ,is there something I can do to get this to shift before tearing it down?
Edited by new restorer, March 20, 2012 - 05:04 PM.
#2 MH81 OFFLINE
Posted March 20, 2012 - 08:18 PM
If the PO never took it out of high range, I wonder if the detent ball is stuck / rusted. You might get some good penetrating oil on the shaft a few times and see if it starts to loosen up. Just don't wail on it, the exploded view looks like either the pin or the fork could be bent if the wrong pressures are applied.
the 8 speed is close to the end of the manual.
http://gardentractor...-repair-manual/
  • caseguy and drbish have said thanks
#3 jusjeepn OFFLINE
jusjeepn
  • 84 Thanks
  • 120 posts
Posted April 08, 2012 - 02:06 AM
Did you get this to work? Didn't think so! 99.9% of the time, a hi/lo issue requires splitting the case!
