Vote for Tractor of the Month
Standard Engine Company
214 replies to this topic
#211 mrf1002u OFFLINE
mrf1002u
  • 95 Thanks
  • 162 posts
Posted June 13, 2015 - 08:15 PM
Jtrojek,
Here is some serial # info as well.
Larry W.
Here is how to read some serial numbers to find out when your tractor was made.
The first two numbers are the last two numbers of the year that it was made.
The letter is for the model of the tractor (see list below).
The numbers after the letter are the consecutive unit number.
We will use this number as an example: 34Cxxx
The "34" means that it was made in 1934
The "C" means that it is a Standard Twin
The "xxx" is the consecutive unit number.
The first and third number are the last two numbers of the year that it was made.
The second number, the 0, has no meaning.
The last numbers are the consecutive unit number.
We will use this number as an example for the other way that the serial numbers were stamped: 309Cxxxx
The "3" and "9" mean that it was made in 1939
The "0" has no meaning
The "C" means the it is a Standard Twin
The "xxxx" is the consecutive unit number.
The letter in the serial number tells what model tractor you have.
The following is a list of the letters that we know of.
"C" = Standard Twin
"CF"= Viking Twin with Bread Box
"CG"= Viking Single Cylinder
"D"= Standard Walsh
"E"= Standard Monarch
"F"= Viking Twin
"K"= Kinkade (smaller)
"L" Kinkade (larger)
"TN" Standard Edgeton
If Your Serial Number Tag is Missing:
On the Standard, the Walsh, the Standard Monarch, The Standard Walsh, and the Kinkade the serial number is stamped on the flat machined surface around the oil fill plug. The serial number on the Standard Twin is stamped on a flat machined surface behind the carb, under where the cylinder bolts to the block. On real early tractors, there is a raised machine surface next to the oil cocks near the bottom of the engine block.
  • Alc, DB1, Tbrooks and 1 other said thanks
#212 jtrojek OFFLINE
jtrojek
  • 1,029 Thanks
  • 553 posts
Posted June 14, 2015 - 04:39 AM
Thanks for all the great info, and I think I will be using it as a lawn ornament, though I may also, just for fun, try to unstick the engine.  Thanks again!
#213 DougT OFFLINE
DougT
    Dog Approved
  • 5,945 Thanks
  • 4,394 posts
Posted June 14, 2015 - 02:45 PM
Larry, most of that is good info but where did this statement come from?
The Twin sported an impressive array of advertised features, especially considering they went on sale in 1931
34 was the first year for the twin.
#214 mrf1002u OFFLINE
mrf1002u
  • 95 Thanks
  • 162 posts
Posted June 14, 2015 - 04:31 PM
Hey Doug :-)
Honestly, no Idea.  Thanks for correcting it though.  Almost every line of that is cut and pasted from different pages and was just stuff I saved for reference.
Larry W.
#215 mrf1002u OFFLINE
mrf1002u
  • 95 Thanks
  • 162 posts
Posted June 14, 2015 - 04:33 PM
I'll correct my document so that isn't repeated.
Larry W.
  • DougT said thank you
