Jd 110 Wiring Help
14 replies to this topic
#1 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted March 19, 2012 - 11:30 AM
Hello,
I bought a 1972 JD 110 with an 8 hp Kohler. One of the wires was off the key and it did not want to start. When I tried to put it back on, I found out that all of the wires were loose. I don't know if they were correct or not. Does anyone know where the wires hooks into the ignition. The wire colors are green, purple, red with white line and white. There are 4 wires and 5 hookups on the key.If anyone has a wiring diagram it would be much appreciated.
Thanks,
DB1
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 19, 2012 - 03:47 PM
Heres a copy of a 110 wiring diagram. Not sure if it's the correct one or not but it should give you enough info to trace the wiring that you have to see if it's the same.
#3 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted March 19, 2012 - 06:03 PM
Hi Brian,
Thanks, but diagram is too old for my mower.
My mower is a 1972. The ignition switch 3497644 has A, B, S, M and R with 5 prongs total.
We need to know what wires go on the A, M and R.
Thanks,
DB1
#4 lyall OFFLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted March 19, 2012 - 08:50 PM
see the attach link - it is the forums here
http://gardentractor...iring-problems/
#5 KennyP ONLINE
  • 40,230 Thanks
  • 46,811 posts
Posted March 20, 2012 - 05:00 AM
Here is a list of what the letters stand for:
M = Magneto
S = Starter Solenoid
L = Lights
A = Accessory
B = Battery
G = Ground
I = Ignition
R = Regulator/Rectifier
#6 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted March 20, 2012 - 07:44 AM
Thanks guys for the information on the wiring diagram.
#7 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted March 20, 2012 - 08:05 PM
Hey, Hey, we got it running. Vroommm!!!
#8 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,498 posts
Posted March 20, 2012 - 09:41 PM
:thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
  • DB1 said thank you
#9 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,498 posts
Posted March 21, 2012 - 11:42 AM
Hey DB...
Got any more pics of the headlight and surround plate? Looks like a nice replacement that I would use for reference on my 120.
#10 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted March 22, 2012 - 09:05 AM
Hi Travis,
Here is the picture of the headlights. I hope it helps you.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 22, 2012 - 10:02 AM
Glad you got it sorted out. Those ignition switches are a bit of a mystery if you don't have the info on what the letters mean.
#12 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted April 11, 2012 - 08:44 AM
Hey Travis did you want pictures of the headlights backside were the wiring connects,too?
I a woman and I wasn't thinking about the mechanical set-up of it but the cosmetic side of it.
Sorry!
Candy
  • Trav1s said thank you
#13 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,498 posts
Posted April 11, 2012 - 11:21 AM
Sorry!
Candy
That would be helpful too! I am trying to come up with something for my 120 project tractor. Any pics you could supply would be gr8-ly appreciated! :thumbs:
#14 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted April 11, 2012 - 01:50 PM
Here is the picture of the backside of the lights. We have a feeling the front plate is not original, but it was a top-notch fabrication.
Good Luck,
DB1
#15 JimT OFFLINE
JimT
  • 1 Thanks
  • 1 posts
Posted March 19, 2014 - 07:31 PM
The fabrication looks great, aclosser picture of back side would help, thanks
