Engine Oil
9 replies to this topic
  • 3,787 Thanks
  • 3,907 posts
Posted March 19, 2012 - 11:03 AM
About ready to get the tiller Troy built Super Bronco out for the spring and need to change the oil.
I'm debating between a Synthetic and Rotella which would you reccomend?
#2 twostacks OFFLINE
  • 479 Thanks
  • 438 posts
Posted March 19, 2012 - 11:40 AM
I run Rotella in all my garden equipment and my wood splitter too. I change everything at the beginning of the season since most have the hours or are near the hours to be changed, and I probably still would even if a had used synthetic. I don't see that the money spent on synthetic would be worth it. Just my opinion and way of doing it. Gary
#3 1978murray OFFLINE
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 19, 2012 - 12:57 PM
i buy cheap oil and just change it more
#4 GTTinkerer OFFLINE
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted March 19, 2012 - 02:26 PM
With the low number of hours most of us put on our personal tractors I would think l that a good brand of oil would work just fine. On several of the golf courses I worked at we used 15W49 AMS Oil in all four cycle gas and diesel engines since most pieces of equipment would get over 400 hours a year and several in the 500 to 750 hours area.
I would never recommend cheap oil in any engine that spends most of its life running at wide open throttle since the oil in an air cooled engine is used not only to lubricate the moving parts but also to aid in reducing the temperature of the metal by convecting the heat to the cooler air swept areas.
#5 Canawler OFFLINE
  • 1,948 Thanks
  • 1,803 posts
Posted March 19, 2012 - 10:25 PM
That's an easy one. Use synthetic Rotella.
They have a "T-5" oil that is a synthetic blend then their "T-6" is a full synthetic 5w-40.
#6 mjodrey OFFLINE
  • 2,356 Thanks
Posted March 20, 2012 - 04:40 AM
I like Amsoil myself.
#7 TerryD OFFLINE
  • 132 Thanks
  • 254 posts
Posted April 04, 2012 - 02:16 AM
Yep. Synthetic oil is a really a must for air cooled engines. The difference in 20 degrees could mean oil that has broken down, or still up to the task of lubricating and preventing sludge.
#8 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted April 04, 2012 - 03:55 PM
I run 30w non-detergent in all my motors without oil filters. With no filter, detergent oil will pick up the crud in the oil & keep circulating in the engine. I use 20w inwinter in snow blower. I tried
10w30 once & when I drained it hot to change it, it was so thin it looked like diesel fuel. That's MHO
& I'm sure a lot will disagree but I get long life from my air-cooled motors.
#9 grnspot110 ONLINE
  • 4,224 Thanks
  • 2,668 posts
Posted April 05, 2012 - 06:14 AM
30 wt. Kohler oil here! I'm told it is made by Quaker State. ~~ Lowell
#10 ducky OFFLINE
  • 1,983 Thanks
  • 4,104 posts
Posted April 05, 2012 - 08:23 AM
15/40 Rotella or other brand of good diesel oil. 5w/40 in the winter. All my equipment does stay in a warm shop.
I change it quit often on the non filtered engines to remove the dirt from the crankcase.
