New "hacksaw"!
18 replies to this topic
#16 KennyP ONLINE
  • 41,444 Thanks
  • 47,379 posts
Posted March 19, 2012 - 04:58 AM
Maybe you can run a pto shaft from your GT to it and run it that way. Make it fit the 3-point and take it all over the yard!
#17 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 19, 2012 - 04:14 PM
Thanks folks for all the hints and tips on operating one of these babies. I guess I'll go out and buy a good quality cutting wheel for it to start with. I will be using it outside and using ear and eye protection. A slow cut would be what I would expect to work well on one of these. The cutting disk is too flexy to put much downward force on it.
Pull Cord! Allright!! ...Next question, where is the gas tank?
Gas Tank? Thought you knew better than to ask that with this crew?
#18 Kurtee OFFLINE
Kurtee
  • 594 Thanks
  • 473 posts
Posted March 19, 2012 - 06:35 PM
Chop saws are very handy. Correct use is important. As someone already said "always buy quality cutting discs". There are different ones available depending on what you want to cut. Always clamp the material to be cut in the vise, ALWAYS. Exploding discs hurt. When you cut you want to push the wheel through the steel as fast as it will cut it without dragging the motor down. Too slow of a feed can cause the wheel to heat up and expand, jamming and damaging the wheel. And as stated earlier, watch out for the razor blades at the cuts. Do not use these for aluminum as it will gall up the wheel and cuts horribly. Aluminum is a different game completely. Just enjoy it safely.
KURTEE
  • JDBrian said thank you
#19 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted March 19, 2012 - 07:08 PM
Thanks for the advise guys. Never used one of these before and appreciate the help. It's a pretty crude devise and plenty dangerous for sure.
Kenny I think it's 3600 rpm so right off the flywheel would get er done!!
