New "hacksaw"!
18 replies to this topic
#1 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 18, 2012 - 03:32 PM
I finally broke down and bought a replacement for my trusty hacksaw. The guy at the store said it would be way faster but it seems kinda heavy and awkward. I guess I'll get used to it! I never did figure out what the power cord was for. :confuse:
Anyways here's some pics
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted March 18, 2012 - 03:41 PM
Very nice Brian! I thought about one of those myself, but then a deal came up that I couldn't refuse!
It's not as shiny as yours, but it gets the job done!
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 18, 2012 - 03:43 PM
I have a dropsaw like that, but mine is WAY WAY older then yours. I cant tell what the base of yours is made from, but mine is made of very thick steel and its very heavy.
  • JDBrian said thank you
#4 HDWildBill OFFLINE
  • 8,984 Thanks
Posted March 18, 2012 - 03:47 PM
That is nice Brian, If you lived closer I'd borrow it and show you what the power cord is for! :bigrofl:
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 18, 2012 - 03:48 PM
Nice Steve! I really just need something to cut metal now that I'm taking up welding and want to make some stuff for the tractors. My days of hacksawing through 1/2"x2" strap are done. I've got tendonitis in my right elbow and it won't put up with that kinda abuse. The bandsaw is a different beast all together. No sparks for one thing! Maybe some day but I really don't have space for any more floor mounted tools right now.
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 18, 2012 - 03:50 PM
A dropsaw! Oh!! Now I get it. Your supposed to drop it. Now it all makes sense!
Seriously though, it's just a cheap made in China saw that is backed by a decent warranty. I won't be putting too many miles on it but it sure will be easier than the old hacksaw.
  • Ryan313 said thank you
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 18, 2012 - 03:56 PM
I've got one of those and while it will sure cut steel. I don't use it much. I find it to be very noisey and burns the steel when cutting.
and leaves wicked burrs to grind off.
I'll eventially replace it with a band saw like Case guy pictured. They make a much cleaner cut
#8 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted March 18, 2012 - 04:20 PM
I had one of those drop saws and it always cut crooked. I finally gave it away.
#9 KennyP ONLINE
  • 40,865 Thanks
  • 47,088 posts
Posted March 18, 2012 - 05:29 PM
Brian, good luck with the saw. Buy good blades for it and it won't try to cut crooked. Found that out the hard way. They can be a big help, just aim the sparks outside.
#10 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted March 18, 2012 - 05:35 PM
Man that sure is easier than then the hacksaw, But watch the sparks cause they have Burned more than one shop. Proud you know what makes it run. Congrats
#11 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted March 18, 2012 - 07:43 PM
Thats not a power cord its a pull start. Make sure you get enough speed though.
#12 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Mine cuts straight, and the burrs are only minor and can be broken off cleanly with a pair of pliers. I always take mine outside when I use it. I use it all the time.
#13 caseguy OFFLINE
  • 1,629 Thanks
Posted March 18, 2012 - 07:56 PM
...My days of hacksawing through 1/2"x2" strap are done. I've got tendonitis in my right elbow and it won't put up with that kinda abuse...
I know what you mean there! I have something similar called Tenosynovitis. It affects pretty much every joint in my body.
:bigrofl: Neither do I! It takes up valuable tractor space, but if you refer to my first post, I would rather not be without it either.
A good quality, sharp blade goes a long way to straightening up the cut. The other thing that plays into it is the feed speed. a nice, slow, steady cut will be straighter than a fast cut. It will also prolong the life of the blade.
The bushings on the drop arm being worn can be a problem too.
#14 mjodrey OFFLINE
Posted March 19, 2012 - 04:36 AM
Nice saw ,Brian.I have one something like it,only mine is a Makita.Watch out ,sometimes they like to track off a bit on the way down. Making for a non-square cut.
#15 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 19, 2012 - 04:53 AM
Thanks folks for all the hints and tips on operating one of these babies. I guess I'll go out and buy a good quality cutting wheel for it to start with. I will be using it outside and using ear and eye protection. A slow cut would be what I would expect to work well on one of these. The cutting disk is too flexy to put much downward force on it.
Pull Cord! Allright!! ...Next question, where is the gas tank?
