Sleeve Hitch Box Blade?
11 replies to this topic
#1 gbrown OFFLINE
gbrown
  • 20 Thanks
  • 90 posts
Posted March 15, 2012 - 08:35 PM
I'd like to build (or buy if I can find a deal, but unlikely in my area) a box blade for my Bolens 1050. Today a coworker told me that a box blade required a 3-pt and could not be used with a sleeve hitch. He said there would be no way to engage the blade. I don't have one to inspect so I can't confirm this. Can anyone help? Maybe I'd be better with a sleeve hitch grader blade (some call this a back blade)? Any advice would be great. Thanks everyone!
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,137 Thanks
  • 4,896 posts
Posted March 15, 2012 - 08:58 PM
I have a sleeve hitch box blade and it works pretty well. The Power King I use it on has two way hydraulics so I have down pressure.
#3 OldBuzzard ONLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted March 15, 2012 - 09:17 PM
Good thing that your co-worker never worked at Agri-Fab and/or Brinly :laughingteeth:
http://www.agri-fab....ts/45-0265.aspx
http://www.brinly.com/BS_38BH.html
Sleeve Hitch box blades have been around probably as long as the sleeve hitch itself.
Now, a box blade WOULD work better when used with a 3-pt, but a 3-pt is not necessary
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 15, 2012 - 09:32 PM
Descendants of the sleeve hitch is horse drawn and i have seen many horse drawn box blades, Graders, Ditchers.
#5 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 15, 2012 - 11:05 PM
Oh so a horse comes with a 3 point hitch? Or does it just sit on the box blade for down pressure while it moves with it's front legs? JK :bigrofl:
  • trowel said thank you
#6 KennyP ONLINE
  • 37,547 Thanks
  • 45,533 posts
Posted March 16, 2012 - 05:13 AM
I just bought a sleeve hitch box blade a while back. I used it to grade a drainage ditch, worked pretty good, but would have worked better with a 3-point (tilt one side down to make a ditch). I have some pics of it in this thread:
http://gardentractor...-new-box-blade/
I plan to widen it and add a 3-point hitch, but will leave the sleeve hitch on also. Then I can use it on all tractors.
#7 gbrown OFFLINE
gbrown
  • 20 Thanks
  • 90 posts
Posted March 16, 2012 - 05:30 AM
Thanks for all the info everyone. Now, to start scheming how I'm going to build one on the cheap...
#8 MH81 OFFLINE
Posted March 16, 2012 - 06:12 AM
I found a back blade and converted it to a box scraper. It works quite well with the obligatory cement block on it.
Couple of pics in this thread: http://gardentractor...dpost__p__14165
#9 KennyP ONLINE
  • 37,547 Thanks
  • 45,533 posts
Posted March 16, 2012 - 06:25 AM
I can get more pics of mine if you want them, gbrown. It does a fine job as is, especially since I added the cutters on the teeth. I was breaking up hard packed gravel base with it, had a 75# RR iron on top of it. I just like the ability to tilt from side to side so you cut deeper on one side.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 16, 2012 - 07:27 AM
I feel the same way as Kenny, really like the tilt function on the 3-point hitch for cutting ditches before laying in the driveway.
If a 3-point hitch can not be had then use 2 small left and right plows (or well casings cut to plow points) in place of the ripper theeth on the edges of the box blade, it will ''plow'', using 2 wheels on the back of the box blade, each adjustable to tilt the blade and a swivel or pivot point at the hitch.
Hopefully this gives a few more idears.
Edited by trowel, March 16, 2012 - 07:27 AM.
#11 KennyP ONLINE
  • 37,547 Thanks
  • 45,533 posts
Posted March 16, 2012 - 07:36 AM
That's a good idea, trowel! Hadn't thought about that. Could use a skid instead of a tooth on the opposite side to hold it up from cutting.
#12 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 16, 2012 - 07:42 AM
There you go, that's a great idear Kenny.
