55 Gal Electrolysis Tank
41 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 13, 2012 - 07:07 PM
I just put together a 55 Gal Electrolysis Tank. I used a whole box of washing soda, and a 6 amp charger. This tank is working fantastic so far. The charger is hitting 6 amp, and the bubbles are a flying. I have the frame for the DB Super Power in the tank now. I will have a video up in a day or 2.
  • Bipitybopityboo, Toolpartzman and larryd have said thanks
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 13, 2012 - 07:23 PM
Can't wait to see your video! Sounds great! Good luck! :thumbs:
  • larryd said thank you
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted March 13, 2012 - 07:42 PM
The weather up here seems to have warmed up enough to get our tank back into operation. I still have a bunch of Workbird parts to get cleaned up.
#4 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 13, 2012 - 07:44 PM
It was in the 80's here today.
#5 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 13, 2012 - 08:21 PM
I really have to try this! I have a horizontal poly tank that's at least 375 gallon ( i forget it's been awhile) I think I will use it for this, as everyone seems to like this method. Any way good luck! :thumbs:
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 13, 2012 - 10:24 PM
Did you use a 55 gallon drum? if so did you add metal or just clip the charger to the drum?
  • Toolpartzman and larryd have said thanks
#7 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 14, 2012 - 03:21 AM
It's a plastic drum.
#8 mjodrey OFFLINE
Posted March 14, 2012 - 05:13 AM
That sound like the perfect size set up.
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 14, 2012 - 09:28 AM
I'm looking forward to the Vid. Would a plastic or Metal drum work best?
#10 KennyP ONLINE
  • 38,263 Thanks
  • 45,876 posts
Posted March 15, 2012 - 04:41 AM
Bill, plastic is best. If you used a metal drum as an anode, it would have all the rust stuck to it.
  • HDWildBill and larryd have said thanks
#11 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted March 15, 2012 - 05:33 AM
This is what we used for our electrolysis tank but we did learn one thing. It needs more anodes and I want to use flat bar stock next time for easier clean up. Let me see if I have the pics:
  • TheFarm2004, KennyP, Toolpartzman and 2 others have said thanks
#12 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 15, 2012 - 08:52 AM
Thanks Kenny, there's a guy not far that sells 55 gal drums for $5 and he has both metal and plastic. My next question is what is the best way to make your anodes and can you have to many?
#13 TheFarm2004 OFFLINE
TheFarm2004
  • 129 Thanks
  • 124 posts
Posted March 15, 2012 - 02:03 PM
The more anodes the higher the current draw will be. Use big rebar and tie them together above the water level. My first 55 gal drum I welded 1/4 rod around the bottom of the anodes and after two weeks of use they were eat in two. Today I stuck an extra anode in to speed up a deck but the tie wire slide down into the water! It was eat up in under two hours.
#14 TheFarm2004 OFFLINE
TheFarm2004
  • 129 Thanks
  • 124 posts
Posted March 15, 2012 - 02:06 PM
Man, I passed up 3 of those tanks for 20 bucks a pop last Saturday! Now I know better!
#15 Masseyman OFFLINE
Masseyman
  • 4 Thanks
  • 16 posts
Posted March 16, 2012 - 08:15 PM
What do you put in the water & how much? Grnd to the part being cleaned & hot to the rods in the water at what amperage? I'm going to build one of these just want to get it right. Thanks guys, great info.
