Awwww Craaapppp
12 replies to this topic
#1 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted March 12, 2012 - 05:30 PM
Well I finally got my 12 hp stock puller engine back togather,finally got the carb tunes,finally got it fired up ata steady idle after about 45 minutes I popped the throttle and guess what?The flippin rod blew out into 7 seperate chunks.So now I gotta buy a new rod,cap,bearings and possibly a piston and new rings too cause the holes where the wrist pin goes is newly slightly eggshaped.Talk about being the bug and not the windsheild.
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted March 12, 2012 - 06:03 PM
That really stinks! Sorry to hear that. Hope that you get it back together soon.
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted March 12, 2012 - 06:08 PM
Wow, that's a bummer!
No noise at idle to let you know it was going to happen?
I guess you can be thankful for two things.
1) it didn't happen on the track
2) it didn't go out thru the block
Hope it fixes quick for you.
#4 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted March 12, 2012 - 06:47 PM
ugh thats not good, sorry to hear that man. Do you know what caused it ?
#5 poncho62 ONLINE
poncho62
  • 2,125 Thanks
  • 1,791 posts
Posted March 12, 2012 - 06:50 PM
There must be a reason for that to happen....Timing maybe?
#6 Cvans OFFLINE
  • 7,304 Thanks
  • 6,387 posts
Posted March 12, 2012 - 09:35 PM
That is a big buuummmmer. Hope you get it figured out before you put it back together again.
#7 mjodrey OFFLINE
Posted March 13, 2012 - 04:55 AM
Oh man,sorry to hear that.
#8 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted March 13, 2012 - 07:24 AM
Sorry to hear of your misfortune. Hope you get the problem resolved and get the engine back together.
#9 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted March 13, 2012 - 12:23 PM
Welll,I think I know what mighta coulda happened.When I put the rod cap on the first time and torqued er down I REALIZED i HAD PUT THE CAP ON THE WRONG DIRECTION,THE ARROWS DIDNT LINE UP.sO i TOOK IT BACK OFF FLIPPED IT ROUND TO WHERE THEM LITTLE ARROWS LINES UP AND PUT IT BACK ON,TORQUED ER BACK DOWN.tHINK i MAYBE MIGHTA STRETCHED THE ROD BOLTS.And at about 2,500 rpms it broke.Atleast thats what I am thinkin anyways.
#10 wawcub47 OFFLINE
wawcub47
  • 68 Thanks
  • 167 posts
Posted March 13, 2012 - 07:20 PM
Sorry to hear that. but thats tractor pullin. hope everything else is o k.
#11 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted March 15, 2012 - 01:33 PM
Done got it back togather and runnin.See this super jenyus mechainc I had,put the rod in wrong and didnt point the oil hole in the cap toward the cam.
#12 caseguy OFFLINE
  • 1,629 Thanks
Posted March 15, 2012 - 03:09 PM
Glad that it's running again! Oil does help keep things moving LOL. Glad that it was a simple fix and hope it didn't cost too much to remedy!
#13 mjodrey OFFLINE
Posted March 17, 2012 - 05:05 AM
Rich,glad to hear you got it back up and running.
