Transmission Problrems Ford 100
6 replies to this topic
#1 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted March 08, 2012 - 07:20 PM
I have a 70 Ford 100 that has a transmission problem anybody out there know anything about them? If I put it in Granny gear I have to remove the shifting lever and take a screwdriver to align the gears so it will roll. When I use 2nd or 3rd gear it sounds like it is partily in 2 gears and clatters. It also jumps out of reverse.4th gear works, but is noisey. Someone said the shifting fork is missing. Anybody know where I can get the parts I need and instructions of how to install them. Thanks AL
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,359 Thanks
  • 5,604 posts
Posted March 08, 2012 - 07:25 PM
Sounds like the shifter is not moving, holding the gears in the proper place for them to work.
Are the detents working?
  • tinbender7 said thank you
#3 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 08, 2012 - 07:33 PM
I haven't ripped one apart yet,But I have 2 of those trans. The one on my 100 is excellent the one on the parts tractor I noticed shifts very hard. I think I remember seeing somewhere that there is a roll pin or something that can shear on the forks and cause this. not sure but I will see what makes it tick. Who knows maybe someone else on here has had same issue? I also came across a service manual that had everything in detail about checking and rebuilding these, now I have to remember where I saw that ( to many fires burning at one time) I'll be back soon, going to do some checking.
#4 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 08, 2012 - 07:40 PM
Well It is not the same book but on here there is a good one also. go to Manuals up top, then click Transmission manuals, you will find one in the list that says Tecumseh/peerless 2300 series repair manual. there is also a parts manual above this one. Download both of them. I flipped through the repair one quick, You will like that one! it has pictures and detailed steps for rebuilding. good luck and happy reading :thumbs:
#5 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 08, 2012 - 08:11 PM
I found better one yet. In our manuals section there is a Tecumseh technicians hand book. that is same as the other repair manual but more pages. On page 119 you will see a great picture of the shift forks and shafts, it also goes into depth about what would cause certain problems.
#6 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted March 08, 2012 - 10:02 PM
i have downloaded the manuals and will take time to study them. Thank you for all the help. The tranny is the main thing left to make this a very nice lil tractor.
#7 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted March 08, 2012 - 10:14 PM
There are to little springs that brake which does not allow the little ball will not stay in detent grove of the shifter rail.I hope this helps.later Josh
