1450 Massey
22 replies to this topic
#16 Masseyman OFFLINE
Masseyman
  • 4 Thanks
  • 16 posts
Posted March 11, 2012 - 07:58 AM
Thanks glgrumpy & you are right. I need a Manuel for this. This is the first 1450 I've seen. Not very many Massey's in this area, I've got them from 7 to 120 hp.
#17 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted March 11, 2012 - 08:07 AM
:welcometogttalk: Masseyman
I have a 1650A and know you'll love your 1450. The "A" designates the rear PTO. There was a PTO shaft of eBay but he was really proud of it. You might check there. Unless you have something to run with it, I can't see much use in having one. The only problem I have is that I have a rear discharge mower deck and grass gets in around the PTO pulleys and they'll rust out and it's almost impossible to blow out the grass without taking everything apart. Good luck with the 1450. Oh, let's see some pictures.
#18 olcowhand ONLINE
  • 41,126 Thanks
  • 31,410 posts
Posted March 11, 2012 - 08:42 AM
Thanks Olcowhand, that's what I thought but the pulley is missing on the hydro drive & so is the upper shaft. What part of Ky you from? I'm in Maysville, 1 hr north of Lexington. That's a nice looking 3 pt mower you built.
I'm between Campbellsville & Hodgenville, about 3hrs from you. I've been through Maysville a couple times in the last year or so, once to get a blacktop sealer machine(for the diesel engine), then 2 weeks later for my Bush Hog T-63 tractor near Coumbia. I liked that new bridge! I went that way to avoid interstates & particularly, going through Cincinnati.
#19 Masseyman OFFLINE
Masseyman
  • 4 Thanks
  • 16 posts
Posted March 11, 2012 - 09:35 AM
I'm not but 1/4 mile from that bridge. Small world!!!
#20 Masseyman OFFLINE
Masseyman
  • 4 Thanks
  • 16 posts
Posted March 11, 2012 - 09:40 AM
Tinner I'd post pictures if I could but don't see a way to do it. Using an I phone so I think it's a little different than on pc.
#21 olcowhand ONLINE
  • 41,126 Thanks
  • 31,410 posts
Posted March 11, 2012 - 09:51 AM
Just 1/4 mile? You must live on the side road just before the bridge on the right, as going toward Ohio???
#22 Masseyman OFFLINE
Masseyman
  • 4 Thanks
  • 16 posts
Posted March 11, 2012 - 10:02 PM
As you are going to the bridge there is a road to the left goes up around a hill & I'm up there. It's right before the cut in the hill & just after the bridge over the valley.
#23 John A. OFFLINE
John A.
  • 1 posts
Posted November 15, 2014 - 11:11 AM
I need some help!  I have a MF 1450 tractor that has only been used with the snow blower attachment.  Problem is I am in need of a set of spindles (PN3020422M91 and 3020423M91). Can any one help with a source to find these spindles or a similar type that I could use?
