Charging
#1
OFFLINE
Posted March 07, 2012 - 11:16 PM
#2
OFFLINE
Posted March 07, 2012 - 11:36 PM
- speedyg said thank you
#3
OFFLINE
Posted March 08, 2012 - 08:33 AM
#4
OFFLINE
Posted March 08, 2012 - 12:41 PM
- Trent Thomson said thank you
#5
OFFLINE
Posted March 08, 2012 - 12:49 PM
- Trent Thomson and HDWildBill have said thanks
#6
ONLINE
Posted March 08, 2012 - 02:57 PM
Some of the regulators are grounding through the mounting tabs. The ones that are have a wire coming off the back side, usually a copper braided wire and it is soldered or riveted to one of the mounting tabs.
I wonder if that is my problem also. Does anyone know where i could find a good wiring diagram for an 800. The one in the parts manual is impossible to follow the route of some of the wires.
The wiring on the early tubeframes is pretty straight forward and easy to follow....
#7
OFFLINE
Posted March 09, 2012 - 01:09 PM
I use dialectric grease on all my electrical connections to prevent corrosion. I have great success fixxing things buy taking apart, cleaning, and grease dab. Found some #12 nuts in stainless for the starter connections, that helps.
#8
OFFLINE
Posted March 09, 2012 - 05:32 PM
